Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 10-30-2006, 05:21 PM
mike8818 mike8818 is offline
Send a message via AIM to mike8818
1997 suburban trans probblems
My borther in-laws suburban shifts hard when i has been driven for a while, its a automatic, I was thinking it needs a fluid and filter change. Any other possabilities of what it could be.
1979 pontiac firebird- for sale/trade
1978 Chevy Elcamino- parting out
Old 10-30-2006, 05:23 PM
maxwedge maxwedge is offline
A990 racer
Re: 1997 suburban tarns probablems
This usually is an issue with the pcs in the trans. A full trans scan will reveal problems that can cause this.
Old 10-30-2006, 05:24 PM
What is the pcs? Dose the trans half to be dropped and split?
Old 10-30-2006, 06:39 PM
A990 racer
Pressure control solenoid, assumnng this turns out to be the diagnosis, the solenoid pack is accessible with just the pan dropped.
Old 10-31-2006, 08:25 AM
Blue Bowtie's Avatar
Registered Offender
Re: 1997 suburban trans probblems
Or the connections to the pressure control solenoid. The main electrical connector on the RR corner of the trans is a potential problem area.
Old 11-03-2006, 07:11 AM
Jeremy-WI Jeremy-WI is offline
It could be ready to set the P1870 code from a valve body that is worn where the tcc apply piston sets. Quite a few wear and leak fluid by and when the PCM detects enough slippage it commands full fluid pressure which causes some hard shifs
