Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 10-30-2006, 04:47 PM
nickr48 nickr48 is offline
Unhappy 4x4 electrical problem 96 tahoe
I have a 96 4x4 chevrolet tahoe and right now im have an electrical problem When I put the tahoe in gear it blows the large 50A fuse killing my radio, wipers,A/C, and power windows. Ive already took it to an electrical shop they checked the whole vehicle and said it was fine that the problem was somewhere from the 4x4 switch to the transmission itself I have done some homework on this and found out there are alot of parts from the switch to tranny was hoping someone could give me some info or if they had a similar problem
Old 10-30-2006, 06:04 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 4x4 electrical problem 96 tahoe
Welcome to AF on your first post.
When you say in gear are you refering to transmission in gear or the 4 wheel drive shift in gear?
The 4 wheel drive part or switches does not use a 50 amp fuse.
The short is someplace else.
Best to get a good wiring diagram and start checking what is hooked to that 50 amp fuse.
MT
MT
Old 10-31-2006, 05:28 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
There are a couple 50 amp fuses that protect multible circuits on these vehicles.
Power distributions goes like this..battery, mega fuse, maxi fuse, braches off to fused circuits.
If the 50 amp is blowing and not the fused circuits, the problem is on the feed from the maxi (50a) fuse to the fuse box where the fused branch circuits are located
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 10-31-2006, 04:33 PM
I talking about when i put the truck in reversal or neutral or drive i dont really use the 4x4 at all. but something is blowing out the 50amp fuse under the hood was told it might be a relay in the 4x4
Old 11-01-2006, 09:43 AM
777stickman 777stickman is offline
Need to know exactly which 50a fuse is blowing. There are at least 2 of them. Look on the inside of the cover or in your owners manual to identify it,
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 11-13-2006, 10:55 AM
Hello stickman the 50a fuse that im having trouble with is the ign b fuse
Old 11-13-2006, 03:33 PM
Kinda thought so but needed your conformation. According to the diagrams in my '98 C/K manual, the IGN B fuse goes directly to the ignition switch. From there with the switch in "run" it powers everthing you're loosing. Problem is all that stuff is protected by smaller fuses in the IP fuse block. That includes the 4WD fuse.
So, if none of those fuses are blowing the problem lies between the IGN B fuse to the IGN switch or from the IGN switch to the IP fuse block.
My thought is that you have a chaffed wire in the column and when you move the shift lever it's grounding the feed from the IGN B fuse and blowing it. Here's something you can try. Move the ign switch one position, from locked towards start. This the OFF position. None of that stuff is powered. You should be able to move the shift lever. Does the fuse blow? If not turn the key one more click to "run". Move the shift lever (probably have to step on the brake). Does it blow then?
Let us know...........Steve
57 Chevy 210
Old 12-15-2006, 05:36 PM
Hey stickman i finally tried what you say to do ok first with key turned foward but vehicle not i move the gears out of park and everything works fine fuse does not blow. but with the vehicle on i move the gears out of park and then the fuse blows.
Old 12-16-2006, 10:24 AM
OK: It really sounds like it's in the column. Need to get in there and look for brown and orange wires coming from the ign switch. Keep in mind that the wire colors may be different on your '96 as I'm looking at a '98 manual. In any case I bet you'll find some bare wires. Because of the air bag system I highly recommend using someone with experience in that area. Good luck to you.
57 Chevy 210
Old 12-26-2006, 03:29 PM
Talking Re: 4x4 electrical problem 96 tahoe
Hey stickman just wanted to thank you for all the help. Thats exactly what my problem was some bared wires in the column that everytime i moved the tilt to adjust the steering wheel of moved gears out of the park position was causing the fuse to blow. Everything is working properly now Thanks again
Old 12-26-2006, 05:29 PM
Good job, man. Glad you found it. Cheers...........Steve
57 Chevy 210
Old 01-21-2007, 12:17 PM
Flopps Flopps is offline
I am having the same fuse blow on my 95 Suburban. As soon as I turn the ignition switch the fuse blows. I traced through the wiring and can't find anything shorting out. Is it possible that the switch might be shorting internally? All the ip fuses are fine. It's just the maxi fuse that keeps blowing. I don't want to spend $150 on a new switch really and have it not be the problem.
Old 01-21-2007, 02:23 PM
cordis cordis is offline
99 tahoe parking light/instrument pannel fuse blows. 176,000 miles no electrical or mechanical problems or wrecks in past. Someone said it could be a bad resistor with heat sink under dash. I found the part but don,t know how to check it. Ohm meter shows no reading when touching the contacts. Help please.
Old 01-21-2007, 04:24 PM
MT-2500's Avatar
AF - Advisor
New different problem start a new post.
MT
Old 01-21-2007, 04:37 PM
MT-2500's Avatar
AF - Advisor
New or different problems needs a new thread started on it.
New thread button upper right of Tahoe forum.
MT
