Old 10-30-2006, 04:19 PM
Absolut Talent Absolut Talent is offline
Send a message via ICQ to Absolut Talent Send a message via AIM to Absolut Talent
96 Blazer, Getting to the head gaskets?
So i got a 96 blazer, I got the upper plenum off, removed the fuel spider, but now I cant get any farther. I see the 8 bolts (4 in front, 4 in back) thats holding the manaifold on, and I can reach all but 1 in the front becasue of the mount that the AC compressor sits on is in the way. And I cant figure out how to remove it. I removed all visible bolts from the front, and its got some wiggle in it, but something is still holding it on.
Just a guess too, but is that the powersteering pully and pump below it? is it all once piece? How can I remove it?
Then problem #2, after that is all removed, and I can get to that one bolt it was blocking, its got that hose comming right out of the manifold
What hose is that for? What size is it? (all wrenches ive tried dont fit, so If I need to buy a new one having a size is great)
After I remove those 2 items, can I remove the manifold and will the headgaskets be accessable to replace them? Or do I need to remove more stuff?
Old 10-30-2006, 06:04 PM
kb3jhp kb3jhp is offline
Re: 96 Blazer, Getting to the head gaskets?
take the bolts out for the bracket and you must pull the power steering pully off to get to the one bolt for the bracket and then the pump and bracket will both come off together and you should be able to get to it
Old 10-30-2006, 06:40 PM
ok... how do I remove the pulley? I dont see a bolt in the middle that I can get off like the other pulleys. Do i have to pry it off or something? or is there a special tool?
Old 10-30-2006, 06:45 PM
maxwedge maxwedge is offline
A990 racer
You need a puller designed for p/s pump pulleys.
Old 10-31-2006, 06:31 AM
muddog321 muddog321 is offline
AF -Advisor
GM loves 18mm on many so invest in a combo wrench and a 1/2 drive socket (brakes use too).
Old 10-31-2006, 03:17 PM
i have this one works great http://www.sears.com/sr/javasr/produ...seBVCookie=Yes it also has many other uses worth the money broke a cheap one from the parts store
