Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 10-30-2006, 10:55 AM
devasq devasq is offline
Right Turn Signal doesn't work
My right turn signal will not work properly. When I signal to the right, the flasher makes a clicking sound about twice as fast as normal which I believe is an indication of a bad bulb. Checked all fuses and bulbs. Replaced the flasher. Same thing. Left turn signal and hazards work fine. When I only go halfway up on my turn signal, works fine. I'm leaning towards the multifunction switch but it seems like a pain to replace. Does anyone have any guidance on it's replacement or the cost? Thanks
Old 10-31-2006, 09:20 AM
rogerlh rogerlh is offline
Re: Right Turn Signal doesn't work
I had to replace the switch on my 98 Sable wagon. Get it done as you don't want to blow the bag. They are very expensive the switch replacement probably cost $180 with labor (in N Virginia) I think the switch was maybe $100.
Old 10-31-2006, 05:58 PM
KimMG KimMG is offline
AF - Advisor
You didn't state the year for your vehicle, so I looked up the information for Roger's '98 The following link is to a part for a '98
http://www.autozone.com/servlet/UiBr...EDimmer+Switch
The following link is to a repair guide for a '98
http://www.autozone.com/servlet/UiBr...3d801b01d0.jsp
Old 12-01-2006, 02:09 PM
Tanasi Tanasi is offline
I have a 97 and had the same problem. I had the multi-switch replaced. Switch and labor was less than $100 but I've got an honest mechanic. According to him the hardest part was dis-assembling and reassembling the stearing column.
