Go Back   Automotive Forums Car Chat > Ford > Escape | Maverick | Escape Hybrid
Old 10-30-2006, 09:09 AM
BombStar BombStar is offline
New to the escape...
01' Escape v6 automatic...120,000 + miles
When I turn the engine on in the morning my idle is verry rough and jumpy. I noticed that once I get her warmed up the idle kinda smoothes out a bit...my temp sensor light is on in the guage cluster.
-All fluids are good
-replaced the plugs last night
Could the problem be my heat sensor?
Has there been any recalls for the Ford Escape 01?
Thanks.
-Adrien
Old 10-30-2006, 11:49 PM
suvguy915 suvguy915 is offline
Re: New to the escape...
Thanks.
-Adrien
Here's a link for recalls www.nhtsa.dot.gov/ Another really useful site just for escape owners is a forum www.escape-central.com
Old 10-31-2006, 02:18 PM
I checked on fords website for recalls & got these on my vin search...
-03s10 Seatbelt buckle cover
-04s13 Powertrain controle module re-calibration
Having it serviced wednesday at the local dealer...I'll post up if this cures the problem.
Thanks for the info.
-Adrien
Old 11-02-2006, 11:17 AM
Idle is a little smoother now...still feels bad though.
The tech gave me a copy of the code being thrown...
Description - P0354
- ignition coil D primary/secondary circuit
- open ignition coil primary circuit
- This TDC may be caused by:
- short to ground in ignition coil primary circuit.
- open ignition coil POWER circuit.
- coil
I'll be taking it to my brother who's a ASE Certified master tech. I'll post up afterwards if I have it repaired.
-Adrien
Old 11-02-2006, 11:34 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Cool Re: New to the escape...
There has been reported..problems with the IAC (idle air control) motor..do a serarch.
Might also be called IAC solenoid or valve.
Old 11-02-2006, 12:19 PM
That has been replaced also...thanks anyways.
Does anybody know where Ignition coil D is located?...facing the engine?
remember there are 6 coil packs for 6 plugs.
Thanks for the info
-Adrien
Old 11-15-2006, 02:01 AM
AlohaBra's Avatar
Hey..did you ever find out where D is ?
My guess is #4.
Old 12-20-2006, 10:05 AM
AlohaBra's Avatar
So...did this problem get fixed?
Aloha...
Old 02-06-2007, 02:22 PM
I'm guessing it's coil #4 too...dunno. I've got some free time tonight & will be wrenching out the problem with my bro...I just hope it's the right coil.
#4 should be the front left coil facing the engine right? The firing order is 123
456
Right?
I'll post up the results.
Thanks!
Old 02-13-2007, 08:44 AM
HA!!!!!!!! Before driving across Houston I decided to take a look for myself. I pulled the plastic cover off, disconnected the battery and WHAMM!! The #4 coil was not even connected!!...No problems now runs super smooth. No codes also. Thanks for the help anyways guys!...Just remember to start off with the smallest solution before getting worried!
-Adrien
