Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-30-2006, 07:48 AM
ABigWeaney ABigWeaney is offline
Oil filter keeps comming off...
i have a 92 talon tsi and the stupid oil filter keeps backing off and leaking all of the oil out. Sometimes the housing comes loose. It has done it to me 4 times so far i keep replacing the oil and filter... what would be causing it to do that?
Old 10-30-2006, 12:20 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Re: Oil filter keeps comming off...
Check to see if you have the correct filter...you'd be surprised how people can get that wrong. Also check to see if it grabs; the threads may be worn out on your car and the filter may keep coming loose.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 10-30-2006, 12:29 PM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
how tight are you tightening it?
I don't think you do, but does your car have an oil cooler?
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 10-30-2006, 10:16 PM
I tighten the filter by hand untill it wont turn no more then i turn it about 1/4 of a turn more with the filter wrench. Yes it does have a oil cooler.
Old 10-31-2006, 01:53 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Did you make sure that the old gasket isn't sticking onto the filter housing?
95 Talon TSI AWD
97 Eclipse GST
Old 10-31-2006, 07:20 AM
Mikelb's Avatar
Do you have any problems with coolant/oil mixing?
What brand of oil filter (el Cheapo, Mitsu OEM, K&N, Fram)? (Idk that this will have any impact, but I think that the cheapo's threads might be easily damaged)...
I've only been doing mine hand tight (with a fram filter w/the grip) and haven't had any problem
Also, are your threads damaged or dirty?
Old 10-31-2006, 07:52 AM
I just took the filter off lastnight, and there was no gasket on there from the old filter but the stud that the filter goes on was really loose so i took it off and cleaned it and put some locktight on it.. hopefully it dosent come off, i was using castroil synthetic with a fram filter. the threads also looked good.
Old 10-31-2006, 11:00 AM
nofear39427 nofear39427 is offline
Send a message via Yahoo to nofear39427
I know a guy who had the same prob with his filter blowing off.Something could be stopped up as well and its just over preassuring.
Old 10-31-2006, 11:23 AM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
I've heard of the problem before and people some times wire the filter up so it cant turn off
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
