Go Back   Automotive Forums Car Chat > Pontiac > 6000
Old 10-30-2006, 03:59 AM
TheHuHu TheHuHu is offline
1990 Pontiac 6000 LE
I just bought this car for $850! It has 68,000 miles and the owner was an old lady so it's a lot of city miles.
However, is there anything I should be concerned about because the lack of long drives she took? And what should I replace now or in the future because of the miles? I heard you need to replace timing chains every 60k-100k miles?
Thanks for all of your help!
Old 10-30-2006, 06:43 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 1990 Pontiac 6000 LE
First of all, what size engine do you have? Make sure to change the oil and I would change the transmission fluid and filter. Don't FLUSH!! Then change the fuel filter, check the brake fluid and if dark change it out by bleeding all four brakes. The serpentine belt may need changed, along with a coolant flush and radiator hose replacement. With that low of miles if she maintained the car you got a good deal!!
Old 10-31-2006, 02:50 AM
It's the v6 model.
And wow, that's a lot of stuff to be replaced. How much will each replacement usually run $$?
Old 10-31-2006, 06:34 AM
Pontiac Guy
It will probably cost you around $200 for parts if you do most of the work yourself. If you have someone do the work for you expect to pay about the same amount in labor. Actually all of the above are normal maintenance items and when cars are low mileage like the one you mentioned these items will deteriorate and can possibly let you sit along side the highway. As for the timing chain don't worry about it. I had a V-6 with 209K and it had the original timing chain. The other items are more important to longevity.
Old 11-10-2006, 01:40 PM
Scrapper Scrapper is offline
AF Premium User
Smile Re: 1990 Pontiac 6000 LE
and if she hasn't had it up to 55 or more don't go running it hard as the pistons might not have been up cylender wall's that high if you do just go up and up little bit more each time...you don't wana crack a wring or wring's....good luck....
Old 04-12-2007, 12:59 PM
dcjredline dcjredline is offline
WHAT???
Are you saying at higher RPM's the pistons go higher in the cylinder? oh yeah? The cast steel connecting rods actually SSSTTTRRRREEEEETTTCCHH at higher RPM's.
Don't take this advice. Pistons go up and down the same distance no matter what the RPM or you cars speed. They are mechanically attached to the CRANK by a steel Connecting rod.
