Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 10-30-2006, 02:55 AM
Hesam Hesam is offline
95 Aurora-Need Help From Mechanic
My 95 Aurora's Service-engine-soon light will only flash when car is crancking to start, instead of staying on for 10-15 seconds and going off.
I took the car to dealer to have the light fixed. They not only didn't fix it, since I got the car back, everytime car makes a little move or I turn the switch, the shock-level control compressor starts to pump loudly and won't stop for 4-5 minutes.
I know it's probably my shocks leaking air or bad compressor but can I disconnect the compressor to get rid of the loud noise of it every minute? if yes, how?
Old 10-30-2006, 04:24 AM
newscarver newscarver is offline
Re: 95 Aurora-Need Help From Mechanic
you can remove the fuse from under the back seat fuse box.. its the one going by the map inside the lid marked elc ...electronic level control
Old 01-19-2007, 01:41 AM
That fuse also disconnects instrument panel, there must be another way to disconnect ELC
Old 01-20-2007, 08:51 AM
55624096 55624096 is offline
Go under the car and unplug the wire to the compressor. There is a electric connector to the compressor motor. This will stop the compressor from coming on but if you have a leak in the shocks you may droop down in the back.
