Go Back   Automotive Forums Car Chat > Chevrolet > El Camino
Old 10-29-2006, 09:25 PM
cherryelky305 cherryelky305 is offline
Send a message via AIM to cherryelky305
Front end swap
Just double checking something. A front end, headlight area and the like, from an 83-87 Camino will bolt right on to an 80 correct? has anyone done this themselves and if so, what problems did you encounter?
Old 10-29-2006, 10:50 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Front end swap
1978-1983 Malibu and 1978-1987 El Camino, will interchange. This is for entire front clips. Keep in mind that through 1981, these cars had single headlights on each side, two in total, while 1982-up had dual headlights (4 in total).
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 10-30-2006, 09:56 AM
Re: Front end swap
Yes, they did have four headlights. Is this a major electrical problem or something fixed with a simple splice?
