Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 10-29-2006, 09:10 PM
himie298 himie298 is offline
Exclamation torque steer
96 Jetta 5sp. when I accelerate I get a pull to the left and when I let off (before breaking) I get a pull to the right. This happens with a moderate to hard acceleration or slowing. Is this a CV. I have checked and cannot see any movement in motor mounts.
Old 10-30-2006, 10:48 AM
Doug Tatham Doug Tatham is offline
Re: torque steer
You're probably right about the CV joint. I'd check the alignment as well just in case. CV joint's aren't cheep to have replaced and it's not real easy to replace them yourself. If you do, you'll need a 12 point torx set. They cost 10 bucks at an automotive store.
Old 11-05-2006, 03:53 PM
Smile Re: torque steer
We were both wrong. it was the forward rubber bushing on the lower right control arm. the wheel was moving 1-2" forward and backward on hard stops and starts. thanks
himie
Old 11-06-2006, 03:25 PM
Re: torque steer
That's scary, you're lucky the front end didn't come apart on you.
