Old 10-29-2006, 07:38 PM
mumiej mumiej is offline
CRX breaks up @3500rpm
Just got a 90 CRX that wasn't running due to the screw on the dizzy rotor comming loose and crackin the module.Replaced the mudule and the CRX fired-up.Now the problem is that once the engine hits 3500 rpm,it acts like it's hits the rev limit,and has no power.Could this be a dizzy problem or fuel problem??Could it be a fuel pump on it's way out,or when the screw came loose in the dizzy it messed something up.Please help.....
Old 10-29-2006, 07:53 PM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
Re: CRX breaks up @3500rpm
check engine lights?
-tony-
2000 honda s2000
Old 10-29-2006, 08:11 PM
yes forgot to post,the check engine lite is on,tried to get computer to get codes,but local auto zone don't have 1 for 90 crx.Is there a way to check for codes??
Old 10-29-2006, 08:58 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Its real easy. Pull off passenger side carpet. Look at your ecu and admire its high-tech greatness. There should be a clear openning on it where there is a red light enhoused. Turn your key to ON and you'll see a quick flash that says the ecu works. Count every flash after that and either look it up yourself, or report back.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 10-30-2006, 12:14 AM
viper-blue's Avatar
viper-blue viper-blue is offline
click this link: http://www.automotiveforums.com/vbul...d.php?t=118785 - look for post #5, it has a list of all the ecu codes. You never mentioned if you set the distributor timing after you replaced and tightened everything...just because it starts doesn't mean its timed properly
89 crx SI - spoiler, custom viper blue paint job, Z6 just completed, stock 14's with a 3 inch drop, sidemarkers, and the stereo
"my crx is like my woman: don't like anyone touching her, or driving her but me!"
Old 10-30-2006, 01:35 AM
very good point viper. anytime you take your dizzy off, you should do the timeing all over. to be on the safe side.
-tony-
2000 honda s2000
Old 10-30-2006, 05:45 PM
Thanks ppl,I got another dizzy,and it runs great.The pick-up in the other dizzy was bad,guess when the rotor screw bounced around inside it messed it up.I think it's going up for sale.
