Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-29-2006, 06:46 PM
goongrinch goongrinch is offline
mustang jumps when shifting from park to reverse
1997 3.8 auto tranny mustang, problem is when you shift from park to reverse the tires will chirp the garage floor everytime and the car jumps, the tranny was rebuilt but this problem was going on before the rebuilt tranny and is still going on after.shifting into drive its normal same with the other gears. any ideas thanks?
Old 10-30-2006, 06:29 AM
72' Stang 351 H/O's Avatar
72' Stang 351 H/O 72' Stang 351 H/O is offline
Re: mustang jumps when shifting from park to reverse
So it chirps the tires,the reverse gear maybe to small,so it gets power alot fast. I'd consider what I just said as a guess. But I see no problem with it chirping,if you don't want tire marks on the floor, park the car in backwards.
Old 10-30-2006, 11:15 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Yep,
Not much you can do. Sounds like the car just wants to let its hair down
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 10-30-2006, 07:33 PM
BADBOY#1 BADBOY#1 is offline
V6 chirps but V8 roast tires
Old 11-06-2006, 10:39 PM
dorfboy dorfboy is offline
Send a message via ICQ to dorfboy Send a message via Yahoo to dorfboy
Gears in the tranny may be smaller as he said, also the rear end may have a lower gear ratio. Have you had some work done on the rear end with aftermarket parts?
Old 11-07-2006, 01:30 AM
351wStang's Avatar
351wStang 351wStang is offline
Is the car idleing abnormally high when you shift to reverse? Have you tried letting it warm up before you take it out of park? You said this was a problem both before and after the tranny rebuild. Has this car always done this or did it just start doing it one day? If so was anything on the car changed right before you started having this problem? Then again your car may just have a little extra spunk.
1969 Cougar
357w & TKO - 475hp
Old 11-07-2006, 01:32 AM
351wStang's Avatar
Another thought, 1st and reverse should have the same numerical gear ratio, try taking the car directly from park into 1st, not just drive and see if it does it. But move the shifter quick so it doesnt have time to hit any other gears before first.
1969 Cougar
357w & TKO - 475hp
Old 11-07-2006, 02:56 PM
check the oil level in the trans when trans is warm. sounds as if you have high oil pressure in the trans. is there a shift kit in that car?? or maybe the brakes dont work to the rear wheels causing the rear wheels to spin while the front ones have brakes stopping them.
Old 11-08-2006, 12:09 AM
351wStang's Avatar
Idle rpm should not spin the tires like that with or without the brake.
But I will agree on the high pressure, thats where I was going with the 1st gear test.
1969 Cougar
357w & TKO - 475hp
Old 11-08-2006, 10:17 AM
Cool Re: mustang jumps when shifting from park to reverse
youre right correct idle speed should not cause the tires to spin, but the idle on this car maybe high as mentioned early. just a thought.(P.S to me even slightly high idle should not cause this)
Old 11-08-2006, 10:21 AM
Did you try leaving the brales applied a couple seconds longer after you shift into reverse to be sure the trans is well ingaged before you leave off the brakes? another thing, do the tires spin as soon as you shift into reverse or whenever you let go the brakes.
Old 11-12-2006, 11:21 PM
have the brakes applied, the car just chirps the tires from park to reverse real quick.
Old 11-26-2006, 01:24 PM
jtvyper456's Avatar
jtvyper456 jtvyper456 is offline
Send a message via AIM to jtvyper456
Tranny could be slipping, did you rebuild it yourself or have a shop do it?
1995 Camaro
40 Series Flowmaster
2 Kicker Comp 05CVR 122 (Dual 2Ohm Voice Coils)
^Kicker ZX550.2 Amplifier^
Old 11-28-2006, 01:00 AM
351wStang's Avatar
You may just have a very tight converter in the car with a stall speed about the same as idle rpm. This could explain the chirp at the shift. Maybe the converter just locks up too early.
1969 Cougar
357w & TKO - 475hp
