Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 10-29-2006, 06:33 PM
aspiderfreak aspiderfreak is offline
97 2.5 leaking coolant
OK this is wierd....I had a leak from my lower radiator hose at the block. I replaced the hose and refilled the coolant.....before I even started the jeep, I saw it leaking again.....drained it again and checked the clamps and fitting of the hose...seemed fine. I have removed the hose/clamp a couple times now and it continues to leak. I cannot see what the problem is. I can't see anywhere else the water would be coming from, but it's wierd that it would be leaking from a clamped hose without even having the engine on and the only pressure the water has is gravity. if anyone has any advice....PLEASE let me know. Thanks
Old 10-29-2006, 10:21 PM
Re: 97 2.5 leaking coolant
actually nevermind.....a friend just emailed me a site that explained it. It is actually the water pump about to go out. the jeep waterpumps have a warning system, it has a small hole that allows a leak once the seal is no longer intact. it just so happens to leak right on the lower radiator hose so it looks like thats where it comes from......heres a link with more info.
http://www.car-stuff.com/jeepwaterpump.htm
Old 10-30-2006, 01:37 PM
tomvid tomvid is offline
That is a really easy job, just did mine this summer. Make sure there is an "R" on the fins of the one you buy. They have a reverse spin on the fan.
http://www.stu-offroad.com/engine/ra...radiator-4.htm
97 Jeep Wrangler SE 2.5L
Things I've repaired:
Thermostat: Crankshaft Position Sensor: Radiator: Water Pump: Fan Clutch: Wires: Dist Rotor: Dist Cap: Plugs: Disc Rotor: Pads: Sway/Stabalizer bar links: Axle Shaft U-Joints : Transmission swap : Brake line : Shocks : Rear Pinion Seal : Transmission Mount
