Go Back   Automotive Forums Car Chat > Games > Gran Turismo Series
Old 09-10-2002, 06:29 AM
NSX-R-SSJ20K's Avatar
NSX-R-SSJ20K NSX-R-SSJ20K is offline
Send a message via AIM to NSX-R-SSJ20K
drifting
Whats the best set up for drifting in GT3 i am about to get this game and i have no idea what to do with suspension set ups
Qualified Automotive Engineer
Old 09-10-2002, 06:47 AM
DVSNCYNIKL's Avatar
DVSNCYNIKL DVSNCYNIKL is offline
R.I.P. DAD 3/25/11
Send a message via ICQ to DVSNCYNIKL Send a message via AIM to DVSNCYNIKL Send a message via Yahoo to DVSNCYNIKL
I've never been able to drift on the asphault, but when you drive in the offroad races, it automatically induces drift.
Why do banks charge you a "non-sufficient funds fee" on money they already know you don't have?
Old 09-10-2002, 11:51 AM
kris's Avatar
kris kris is offline
Off playing with fire.
You also need to turn off the two options. Damn, I don't remember what hey are right now. Something like TCS, and.... I will have to check when I get home. But they can be found on the same section that you select auto tranny, or manual tranny.
Old 09-10-2002, 11:55 AM
DVSNCYNIKL's Avatar
R.I.P. DAD 3/25/11
Yeah, the traction control and the one that applies the brakes while turning.
Old 09-21-2002, 08:49 PM
SinisterSavior's Avatar
SinisterSavior SinisterSavior is offline
Send a message via AIM to SinisterSavior
Not an expert but.....
set camber angle to 0.0 on front and rear
set ur shock rebound +2 than shock bound
set ur stablizers up 2
set brake balance high like 14
acs:low 0-2
tcs:low 0-4
I like the Supra RZ. You could go to GameFAQS and go to GT3 and look for the drifting faq. Helped me out
Old 09-22-2002, 01:42 PM
darklight darklight is offline
i also like the supra for drifting, if you use simulation tires, you can really get some weird drifts going on even with TCS.:smoker2:
Old 07-03-2003, 12:13 PM
Shinez's Avatar
Shinez Shinez is offline
Woo here's where I accel in Gt3...The drifting.....Alright it all depends on what car you want to use, and how you want to drift..Do you want Speed drifting?...Exhibition drifting? and if you want exhibition drifting, do you want long slow drifts..or long complex drifts at a moderate speed?
If you want speed drifting, the best technique to use is gett about 600HP in some car, equipe it with Super soft tires, turn the TCS and ASM all the way to zero
You'll want to adjust the braking distribution to where the rear get's almost 2 times as much braking as the front tires...That will stabilize you in the 4 wheel drifting (which keep in mind does't mean you're using a 4WD car)
Well i'll just give you the settings for one of my cars and you can fidget with them ok?...This car is for exhibition drifting
Subaru 22B
HP 350 ish range
T3 tires
ASM: 0
TCS: 0
Brake balance: 9 /20-22
Ride height:-Lowest whatever that is...
And that's about all you need for most cars, the only variaion being Tires and power level...
-1998 BMW (E36) M3-
~Dinan Drop In Filter~
~Dinan Exhaust~
(Wishes he had Andrew Racing F's
-1991 Mazda RX-7 Turbo II-
(Originally had a Blown/melted 13BT)
Now has a 13B-REW
No Mods to the roo as of yet
-1993 Honda Civic VX-
B16A SiR II
Milled throttle body
ported intake manifold
skunk 2 Valve's
Skunk 2 Springs
Skunk 2 Retainers
Bronze Valve guides
ITR intake & Exhaust cam's
AEM Cam gears
lightened flywheel
Stock geared Y2 Transmission
Spoon 1.5way LSD
Ported exhaust manifold
2.75" Headerback exhaust
Spoon vtec Controller
Old 07-09-2003, 02:31 PM
drifterX's Avatar
drifterX drifterX is offline
I use the 240sx with simulation tires and change some settings and its the best drift car in the game. I think
.:drifterX:.
Old 07-09-2003, 05:07 PM
simdel1's Avatar
simdel1 simdel1 is offline
i had some fun with a dodge viper once. tuned it to the max (something like 1000bhp) i turned asm and tcs to zero, fitted road tires and went driving. now that teaches you how to be gentle with the accelerator, the only way round the corner is sideways. oh, i can also get it to do a burnout in 6th gear
Simon
