Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 10-29-2006, 04:26 PM
davybprelude93's Avatar
davybprelude93 davybprelude93 is offline
Send a message via AIM to davybprelude93
ac leak under my dash
ok there is a leak under my dash which seems to be water, but it only leaks if i leave my ac on for about 30 minutes to an hour. I can't figure out what it is, or how to fix it. So if anyone has any idea on a solution, please let me know. Thanks in advance.
Old 10-29-2006, 09:59 PM
lilwhitelude lilwhitelude is offline
Send a message via AIM to lilwhitelude
Re: ac leak under my dash
Your AC drain is clogged up.. look under your hood and find your drain,, probably pretty low on the firewall on the passenger side, stick something firm in it to dislodge whatever is clogging it. If you can not dislodge from outside of vehicle,,you will have to disasemble airbox assembly and clean from inside of the car.. make sure to get a manual on the car before disasembly,, make sure to disable airbag first.. etc..
Old 10-30-2006, 07:25 AM
thanks
Old 10-30-2006, 10:25 PM
no prob.. Hope it works out for ya.
Old 11-11-2006, 06:43 AM
kaimanson's Avatar
kaimanson kaimanson is offline
Yep should be that...turn on the ac for a few mins and water should come out under the car (passenger side)...if that is your problem try to insert something little by little in the drain hole...be very carefull while doing this....
