Old 10-29-2006, 01:18 PM
choochootrain choochootrain is offline
Unhappy 02 Grand Prix with extended crank
Hi I have a 2002 Grand Prix GT, with the 3.8 liter. This problem just started this morning. When you go to start the car it has an extended crank time, It doesn't matter if it is a cold start or a warm one. Once it starts, the RPM's go up to about 2000 then come back to normal. Other then that it runs and drives like normal. I am new to working on Pontiacs so anyone with some advice would be great. Thanks
Old 10-29-2006, 01:54 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 02 Grand Prix with extended crank
Have you checked fuel pressure to see if in specs and how old is the fuel filter? One cause of extended crank time may be the fuel pressure regulator or insufficient fuel system pressure. Checking fuel pressure will confirm whether it is working properly. There is a Schrader valve where a pressure tester can be connected at the fuel pressure regulator located on the left hand side of the front fuel injector rail.
Also, high idle can be cause by a loose or bad vacuum line. Idle air controller (IAC) is another possibility.
Timeslip 08/12/06
AF Community Guidelines
Old 11-14-2006, 07:57 PM
It turned out to be the fuel pressure regulator.
