Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 10-29-2006, 10:19 AM
Z71Jason's Avatar
Z71Jason Z71Jason is offline
Montana Tranny Problem? rpm bounce
I have a 2001 Montana, Lately when Driving the rpms seem to bounch a few hundred rpm's. Every so often the thing shifts pretty hard also. It accelorates just find, I don't beleive the tranny is slipping. ANy ideas? I done a search, might it be the filter? Thanks in advance. Jason.
Things I throw money at:
'95 Chevy Z71
'01 Pontiac Montana
'36 REO Flying Cloud
'01 Blonde hair, Blue eyed Daughter
'71 Blonde hair, Blue eyed Wife
Old 10-29-2006, 07:00 PM
hufhouse's Avatar
hufhouse hufhouse is offline
Re: Montana Tranny Problem? rpm bounce
Is this when you are trying to accelerate slightly around 45 MPH?
I have that problem and I've been trying to figure out the cause. I think I'm going to take it to a good transmission guy I know.
Old 10-29-2006, 10:20 PM
Z71Jason's Avatar
It doesn't always happen. My wife said it didn't do it at all today. I notice it happens driving around town and on the highway. This damn thing has been nothing but trouble since we bought it. Always something going on with it....
'95 Chevy Z71
'01 Pontiac Montana
Old 10-30-2006, 06:36 AM
hufhouse's Avatar
What happens with ours is also sporadic, but I've narrowed it down to this.
If you are on a nice level road going about 45-50, and you want to accelerate very slightly, not punch it, just move from say 45 to 47, it seems like the transmission gets confused and can't decide whether to downshift or stay in high gear, and it just pulsates. The tachometer bounces up and down and you can feel a pulsing. If you press down harder on the gas, it downshifts and everything is fine.
This also happens when you are going about the same speed (45-50) and you start up a slight incline and you need to give it a little more gas.
Take it for a drive in the country and see if that re-creates the problem.
If so, I'll let you know what my transmission guy says. Maybe this will be enough to kick me into gear (no pun intended) to call him!
Old 10-30-2006, 09:20 PM
troy1 troy1 is offline
AF -Advisor
Harsh shifting may be a bad PCS look for a p1811 max adapt code set. Get it scanned a p1811 will not set a SES light. A bad PCS can cause the TCC to unlock/lock or not regulate properly.
Old 10-31-2006, 11:40 AM
hufhouse's Avatar
Troy must be the Montana god of Transmissions.
The only acronym I understood was SES for Service Engine Soon.
What's a PCS and TCC?
I sure don't want my PCS to lock my TCC.
I think.
Old 11-08-2006, 01:27 PM
lbrazzi lbrazzi is offline
Red face Re: Montana Tranny Problem? rpm bounce
I have a 2000 Montana which was doing the same thing, it turned out to be some sort of electronic solenoid switch which is in tranny. The part costs very little but there is a lot of labour, tranny has to come out. Of course it happened just outside my warranty period, it cost around $850 to do.
I hope this helps!
Old 12-11-2006, 09:49 PM
LittleC LittleC is offline
We had the same problem; hard shifting then overdrive went out. After it cooled down it would work again for a while then go out again.
Round one they replaced the TCC (torque cultch converter) solenoid & the PCM. Now it's doing it again and I'm tired of fighting with my service rep about it. I just rest the code and it stops for a while. I'll take it back again in a few weeks when I feel like arguing again.
