Old 10-28-2006, 10:29 PM
TNEGRETE TNEGRETE is offline
Exclamation Got Engine Problems
Hey People What Up I'm New Here So Bear With Me, Jus Got A 92 3000gt Sl Bought It For 1700$, Here The Catch.. The Car Has 215k Miles On It, Question Is: Car Seems To Studder A Bit When I'm Around 2k Rpm And I Punch, Its A 5 Speed, Happens In Any Gear Around 2-3500 Rpm, Can Someone Help?...thanx For The Help Everyone
Old 10-29-2006, 02:07 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Got Engine Problems
welcome to AF!
please read our FAQ thread. it covers most common problems and will better educate you on these cars.
as for stuttering problems, check your ISC/IAC servo motor, throttle body, MAS, plugs and wires. do a search on here to find more info about each one. also, check out www.stealth316.com for some great detailed information on the aforementioned parts.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
