Go Back   Automotive Forums Car Chat > Volkswagen > Passat
Old 10-28-2006, 10:55 PM
kyserroll kyserroll is offline
passat that is slow
I have a 99 passat. The timing belt broke. 11 valves were replaced. Now the car is so slow. What else might be wrong with the car. It ran fine before. Cam shaft? Valve sticking? My mechanic (different from the one who did the valves) says that the car is not exhausting correctly. He disconnected the exhaust and still no difference. I just need some direction as to what to do with this car.
Old 10-29-2006, 08:50 AM
kmohr3's Avatar
kmohr3 kmohr3 is offline
Send a message via AIM to kmohr3
Re: passat that is slow
I would have someone double check the cam timing.
Old 01-02-2007, 05:22 PM
VW816 VW816 is offline
i agree..if the timing belt broke and it ran fine before you fixed it i would probably say that the timing is off.
Old 01-03-2007, 10:18 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
If the cam timing was off it would set a check engine light for cam position sensor range/performance, or cam position timing over advanced.
Do a compression test (avg is 60-65psi / cyl)
Also did they replace the timing belt tensioner and all the rollers and water pump? If the belt roller was over torqued (15nM) than the tensioner cant properly tension the belt and a large loss in performance will occur.
Old 01-04-2007, 12:30 AM
kmohr3's Avatar
60 - 65 psi seems a little low for normal compression if you ask me. On my old A2 Jetta 8 valve RD motor I got between 190 - 200 psi per cylinder.
I had left the dealer by 1999, so I am unsure if they were still using the 4 cyl 16 valve motors. However, once I found a 16V that was running poorly after a head repair and after examining the motor found that one of the 2 cams was out of time - not by much either - it made a significant difference after resetting the cams to the proper position.
Old 01-07-2007, 11:15 PM
VDUBMAN
60-65 psi is normal compression for the v6 32v engines, yea its low but its specs. I was amazed the 1st time also (I had a no start and checked compression and said yea it needs an engine, then looked up specs and found it is ok)
But with obd2 the ecm and cam position sensors will pick up incorrect cam timing within 5min or less of driving.
