Go Back   Automotive Forums Car Chat > MG > MGB
Old 10-28-2006, 08:33 PM
va1975 va1975 is offline
clutch
I have a 75 mgb
when the car in not running it will go into any gear
when i start it it will not go into gear or change gears
does anyone know what this could be
Old 10-29-2006, 12:11 AM
KimMG KimMG is offline
AF - Advisor
Re: clutch
Have you check the resevoir for the clutch master cylinder?
Old 10-29-2006, 04:52 AM
Flash75 Flash75 is offline
AF - Advisor
Re: clutch
If you have fluid in the clutch master cylinder and see no obvious signs of leaking do this. Have someone push the clutch pedal down while you check the movement of the push-rod connecting the slave cylinder to the clutch fork. It's on the passenger side of the car for USA left hand drive cars. The push-rod should have about 1/2" of travel if it is working properly. If not you have a hydraulics problem. It could need bleeding or either or both cylinders may need rebuilding.
Clifton
