Go Back   Automotive Forums Car Chat > Pontiac > Sunbird/J2000/2000 Sunbird
Old 10-28-2006, 08:03 PM
hagardreams hagardreams is offline
93 sunbird running rough after gasket change
We had a bad oil leak, and changed the oil pump and the oil pan gaskets. After putting everything back together, it is running very rough. We tried several times to adjust the timing by taking the belt off, and moving the teeth over one notch at a time. We got it to where it sounded right, then after getting the rest of the parts back on, it was worse than ever, plus the oil was leaking even worse.
Is there an easy way to set the timing without using a timing light?
Thanks so anyone who can give advise. Julie
93 sunbird 4 cyl 178.000 miles, OHC
Old 11-04-2006, 01:19 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 93 sunbird running rough after gasket change
Those engines require special tools when replacing the timing belt. It's pretty common to have them jump time. Since it's an interference motor, if it gets off too far, you may bend a valve or two (or all) due to piston/valve contact.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
