Old 10-28-2006, 05:46 PM
poppabear_093 poppabear_093 is offline
89 s-10 4.3 backfires through tbi until good and warm
checked vacs and she runs strong when it's warm but until then.... she'll backfire and shut down. any ideas?
Old 10-28-2006, 11:04 PM
twistedtech twistedtech is offline
Re: 89 s-10 4.3 backfires through tbi until good and warm
Cool temp sens? Thjinks it's to cold outside.Maybe.
If it ain't broke.......screw with it till it is.
Even at a Mensa convention,
Someone's the dumbest person in the room.
Old 10-29-2006, 01:35 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
When is the last time you did a tuneup and changed the cap and rotor?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 10-29-2006, 06:20 AM
tuned it up about two months ago,cheap champion plugs though. where would i locate the temp switch and wouldn't it rev higher it it thought it was cold out ?
Old 10-29-2006, 06:21 AM
also it ran fine for about a month
Old 10-29-2006, 12:09 PM
BlazerLT's Avatar
AF -Advisor
Not always at all.
What did your tuneup include?
Do you know how to set the base timing?
Old 10-29-2006, 01:16 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
my 86 was backfiring thru the TBI on the upshit. turned out to be spark plug wires.
Old 11-01-2006, 12:41 PM
base timing? you got me on that one ( haven't got a clue) I just want it to run for about six months while a 350 is being built for me
Old 11-01-2006, 01:49 PM
BlazerLT's Avatar
AF -Advisor
You have to remove the brown and black timing wire from PCM under the glove box carpet area, then set the timing to zero, and then reconnect the timing wire again and reset the computer by pulling the negative battery cable for 10 minutes.
Old 11-01-2006, 01:58 PM
being a newbie please don't think I'm COMPLETELY STUPID but.... set the timeing to zero ie timing light? under the hood ?
