Old 10-28-2006, 05:44 PM
amesjm0431 amesjm0431 is offline
Coolant Pooling on Engine
I am having a coolant loss problem and it is pooling onto the top of the engine block under the supercharger. I have a 2001 GTP with 107k miles. On occasion when I make a hard right turn or stop fast I get steam from underneath the hood from the coolant spilling onto the hot trans as well as the hot engine underneath. Any help would be greatly appreciated.
Thanks!
Old 10-28-2006, 08:27 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Coolant Pooling on Engine
Check the coolant elbow just under the snout of the supercharger. It may have a small crack causing the coolant to spray out. They are not expensive at a dealer nor are they hard to change.
Old 10-29-2006, 11:28 AM
Baja4Autism Baja4Autism is offline
You may want to check your lower intake manifold gasket also. I just did a similar job on a friends 96 3.4 liter. The symptoms were idendtical to yours. I read on another pontiac forum, ***Edited Out by Moderator***, that it is a common problem if you run DexCool and then mix traditional green antifreeze in your system. It also went further and explained that the chemical makeup of DexCool is known to eat through the rubber on the lower intake manifold gasket sealing surface. You will likely find lower compression in various cylinders due to this gasket leak, yet your compression will return to normal or slightly higher readings once the gasket is replaced.
Old 10-29-2006, 11:35 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Baja4Autism,
Sorry but our rules prohibit a general referral to another automotive forum which includes any url that leads to a registration page. The url in your post has been edited out.
You may post a direct link to another auto forum tech procedure or thread as long as it is relevant and similar to the issue in this thread.
Thank you for your future cooperation and welcome to AF.
Timeslip 08/12/06
AF Community Guidelines
