Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 10-28-2006, 04:29 PM
theragtopguy theragtopguy is offline
Cruise Control Problem
1997 Nissan 200SX-SE. Put a new clutch cable on. Reconnected everything, cruise doesn't work now. Worked fine before.
When dash switch is engaged, it turns on green like normal. When the 'set' switch on th wheel is pressed, the green dash 'cruise' light comes on and flashes, but it doesn't work. Won't turn off until dash switch is turned back off. I tried adjusting the switch at the clutch pedal, turned it in until it moves the pedal, still doesn't work.
Anybody have familiarity with this at all?
Thanks
Old 10-28-2006, 09:46 PM
Re: Cruise Control Problem
Found th problem-loose connector going into the pump under the hood.
Works great again!
Old 11-12-2006, 12:45 AM
nismo_pilot nismo_pilot is offline
Send a message via AIM to nismo_pilot
great to hear
2005 Aztec Red Spec-V
Nismo header, ES MMI, AEM CAI, UR Pulley, TB Coolant bypass, TWM SS, Kumho Ecsta's, 2x JL Audio W0 subs
9.02@ 84.4mph in the 1/8th....... Driver > Car
