Wont Start!!
Hi all...This is my first post...I have a friend with a 1997 Buick Lasabre 3.8l engine.
The car wont start...its getting alot of gas and there is spark but it wont start. Turns over fine but we need to stop the gas pump and dont know how...The manual is useless and we tryed all the fuses. Can anyone give any ideas as to why it wont start. Thanks all....Cool forum. |
Re: Wont Start!!
I dont know much about resilving this problem other than bringing it to a mechanic and them hooking it up to a computer. I'll look in search engines and see if i can find something helpful for you.
Re: Wont Start!!
This might be of some help---->http://www.ehow.com/how_112584_troub...-car-wont.html
Re: Wont Start!!
Here is a list of websites that may help you and your friend. Best of luck!!!!
Pete http://www.google.com/search?q=car+w...en-US:official
Re: Wont Start!!
Re: Wont Start!!
Well it turns out ....It was a blown head gasket. Which means, no compression, which means no start.
Blown head gasket?
This is very rare on a 3.8! It would take extreme abuse to “blow a head gasket” to the point of (0) “no compression”. Did someone do a compression check and do you have a copy of the compression check? Even with a blown head gasket, you should have enough compression to start the engine unless, you have coolant in the combustion chamber. Coolant will “put out the fire” on the plugs. Are you sure that the car does not have a UIM (upper intake manifold) failure? This is a very common problem on the cars with the plastic intake where the EGR tube burns a hole in the intake coolant passage near the TB (throttle body) opening. ![]() Keep in mind, the pressure in the combustion chamber is far greater than that in the coolant system and if the head gaskets were blown, the combustion gases would overcome any pressure from the coolant system. You need to provide further diagnoses of the problem. This simply does not make sense! ![]() Was the problem resolved by replacing the head gaskets?
Knowledge can be communicated, but not wisdom! ![]() ![]() Last edited by HotZ28; 10-28-2006 at 07:52 PM. |
Re: Wont Start!!
