Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 10-28-2006, 03:45 PM
shaneland shaneland is offline
Chevy engine offset
Hello all,
We have a 40's Ford frame with a 70's Camaro subframe attached to the front. The subframe was computer aligned so it should be ok. The problem we are having ...
We used 70's Camaro motor mounts and a 350 Chevy motor. The Motor seems to be off an inch from one side to the other. Is a small block offset? There is a factory hole in the center off the cross member. The front of the crank where the pulley goes does not line up with this hole OR the center of the cross member. Is it suposed to be like that??
Thanks
Old 10-31-2006, 11:29 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Re: Chevy engine offset
I know some of the Novas had offset mounts to give the steering shaft/box and exhaust manifold more clearance. I guess the Camaro was the same deal. Make sure you have the mounts on the correct side too. You might want to try a set of mid 60's Chevy pickup truck or Impala mounts.
Bob
Old 11-01-2006, 05:05 PM
jveik jveik is offline
yeah the smallblocks in the 73-87 pickups are all centered too
