| Cars/Parts for Sale/Exchange Sell your car and parts or post what you are looking for. |
Toyota MR2 Turbo project for sale :( :( :(
*****THIS POST IS STILL BEING EDITTED******
Sigh. Well.. Ive decided. Im selling my MR2 turbo; either as a project with all the aftermarket parts ive purchased, or ill part the project (not the car) out. I just cant hack it, im a broke-ass kid, all the money im spending on it could be helping me through college, so i have to make an "adult" descision. It has to go. Heres a thread of the complete history and progress of the car: *http://columbussr.proboards22.com/in...ead=1135402568 ------------------------------------------ The Vehicle is a 1991 Toyota MR2 Turbo. VIN# (Will edit) It was produced as a turbo, it doesnt not have a swap. Its black, 5spd, t-tops. The motor is almost completely uninstalled. It has bad piston rings in cyl number one. The motor is literally 3 bolts away from being able to be lifted/dropped out. That saves you $1500 in labor... ![]() A perfect candidate for a motor build, or even a V6 swap car.. Especially with the parts that have been replaced. The Good *The paint is a 7/10. Still shines quite nicely. The rear wing has a small chip in the edge, which can easily and cheaply be fixed. *I am only the second owner of this car since 1991. *Both owners took extremely good care of this car. *Replaced: -Completely rebuilt transmission. Shifts flawlessly, very strong. -Exeedy clutch -Ball joints -93 Wheels -Spark plugs (NGK's all around) -02 sensor -Full OEM ignition component replace (wires/cap/rotor/plugs) -Cold start injector / switch -Water temp sensor -Replaced OEM dampers with KYB AGX 4 way adjustable's, KYB mounts, KYB boots. -Prota alternator -Hoses number 3, 5 in the Coolant lineup. -Both seats, center armrest. The interrior is nearly perfect now. *Replaced front turn signals with crystal clear ones, orange bulbs. *The entire car is extremely strong. It makes no noises, has no creaks. The Bad -There is a large gash in the drivers side fender, its done. A tow truck did it, and im still in the court processes of getting them to pay for it. -The cars chassis has about 215,xxx miles on it. -It does not come with a stock exhaust, as i planned on putting my car. ![]() ![]() ![]() ![]() ![]() ![]() ![]() *******AFTERMARKET PARTS******* -JE 8.5:1 Special Order Pistons, rings, wristpins $450 -Bradi rear slotted rotors, Brembo front slotted rotors. $350 for all 4. ![]() -XSpower complete turbo kit, $750 Comes with: >T04E Turbocharger >Equal length tubular exhaust manifold >XS external wastegate >Divorced 3" downpipe + Support bracket ![]() ![]() ![]() ![]() -Turello center-feed short logstyle intake manifold, $300 ![]() -Wolfkatz complete CNC machined, top-feed conversion, bored fuel rail, 880cc Delphi fuel injectors, and the adapter clips for a complete bolt-on solution. $650 (725.00 new) "he Ultimate 3S-GTE Top Feed Fuel Rail. Will work with injectors sizes up to 160 lb/hr (~1700 cc/min) good for over 800 whp! >Gen II and Gen III models available in either polished or anodized balck! >The only TFFR compatible with your stock supply line, stock FPR, and stock return line when using a Walbro or Supra fuel pump." ![]() ![]() - HKS Hi-Power exhaust, $300 ![]() - Cross drilled/slotted rotors. Brembo fronts, Bradi rears. $300 for all 4. - Greddy rear strut bar (this thing is deisel..) $115 -VMAX Anti Torque Bar $ 100 ![]() -Extra OEM fuel rail, modified for center-feed. Comes with OEM RC-cleaned 440cc injectors, $110 ![]() Contact Info: You can contact me at [email protected] or under AIM : Mekkahfire. Thank you everyone.
1991 Toyota MR2 Turbo, Black. Hoping for 440rwhp, Mid 11's! http://www.cardomain.com/ride/2260717
Re: Toyota MR2 Turbo project for sale :( :( :(
how much and where are you loacted cause my buddy is looking to buy an mr2
