Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 10-28-2006, 01:34 PM
jamesrpottorff jamesrpottorff is offline
O2 Sensor 97 K1500 4wd Need Advise
Took My K15004wd To Auto Shop They Put It On Computer Because Service Engine Soon Light Was On . I Have Spent Over $4500.00 In Recent Repairs, Guy At Shop Stated It Was Burnt Coil Wire Which I Replaced Under Warranty, I Had Major Tune Up In June Of This Year. How Hard Is It To Replace 02 Sensor. Truck Runnin Real Bad And I Am An Single Income Family With 5 Kids Anyone Have Any Advise.
Old 10-28-2006, 01:47 PM
maxwedge maxwedge is offline
A990 racer
Re: O2 Sensor 97 K1500 4wd Need Advise
Welcome to AF, there are 3 o2 sensors, which one and why do you think you need a new one?
Old 10-28-2006, 06:16 PM
THANKS FOR INFO ON THREE OF THEM, WHEN I TOOK IT TO AUTOZONE THE PLUGGED THIER LIL COMPUTER IN MINE AND THE CODES THE MAN SAY IT PRESENTED WAS MIS FIRE ( DUE TO IGNITION COIL WIRE BEING BURNT) AND 02 SENSOR NEEDED REREPLACING. DOES THAT SOUND ACCURATE TO YOU? I REALLY APPRECIETE YOUR RESPONSE AND ANY ADVISE THAT YOU MAY BE ABLE TO OFFER
Old 10-28-2006, 07:48 PM
A990 racer
You need the codes plus a misfire can set an o2 code, try clearing them and see if the o2 code comes back if the misfire is corrected, then rescan and post the actual code.
Old 10-29-2006, 12:36 AM
Ok Thanks, I Had A Rescan And It Came Back Mass Air Sensor, Please Excuse My Lack Of Knowledge, But Try Cleaning What, My Truck Runs Real Rough Till About Thirty, Then It Smooths Out. Am I On The Right Track? Thanks Again For All Of Your Help
Old 10-29-2006, 12:37 AM
Sorry Misread Your Previous Message , Trying Clearing The Light And See If It Re Trips, Is That What You Are Saying
Old 10-29-2006, 10:35 AM
A990 racer
Exclamation Re: O2 Sensor 97 K1500 4wd Need Advise
Do you still have the misfire? What does the code say for the maf? This seems to be bouncing around here, AZ cannot diagnose this problem, you may need a pro here to analyze live data on a real scanner, not a code reader.
Old 11-03-2006, 08:24 AM
Jeremy-WI Jeremy-WI is offline
Actually there are 4 O2 sensors, on a 5.0 and 4.3 there are 3 between the engine and the cat(one close to each exhaust manifold and one after the y pipe) and one after the cat. On the 350 and 454 with the dual cats there are two pre cat sensors and two post cat sensors. The two O2 sensors closest to the engine(called bank 1 sensor 1 and bank 2 sensor 1) are the only ones that can affect how the engine runs, the other two are there to monitor the efficiency of the catalytic converter.
Has the fuel pressure been checked(key on engine off)? Does the pressure hold within spec(59-66psi) after the fuel pump quits running? Has the fuel filter been changed recently? Did the problems start after having the intake manifold gasket replaced?
Old 11-05-2006, 05:15 PM
wafrederick wafrederick is offline
Banned
There is another thing to check and it involves pulling the distribitor.The vortec 350s have problems with the distribitor gear,it will run rough with a worn out distribitor gear.Look for shiney spots and most auto parts stores stock the distribtor gears.Make sure to mark the distribitor before pulling out,the timing is not adjustable and has to be set with a scan tool(0 degrees,look for the cam sensor retard)
