Old 10-28-2006, 10:27 AM
randy deel randy deel is offline
car won't start
i have a 94 lt1 firebird, i changed the distributor,and now it won't start.it back fires when i try to start it.i've checked the plug wires over and over.and i don't know what's wrong. could some one help.
Old 10-28-2006, 08:28 PM
my car won't start
ok i got this lt1 94 firebird 5.7 off this guy and he told me all the car needs is a starter then it will run well i got one and it still would'nt start so i put a new coil,controll modual,spark plugs,disrtibutor and cap ,fuel filter,for the car and after i put the distributor on and then when i put the distributor back on it back fires through the exaust.would the key switch have any thing to do with it or the timing. someone please help asap.
Old 10-28-2006, 10:58 PM
twistedtech twistedtech is offline
Re: my car won't start
Nope.You got the dist out of time.Short story.Pull #1 plug,2 guys,hold finger in plug hole.Bump,BUMP, key,get a POOF , that is TDC.Line up timing mark on crank pulley,drop dist so that rotor is pointing @#1 on cap car will start,set timing.Sounds like you out 180 or at least out.
If it ain't broke.......screw with it till it is.
Even at a Mensa convention,
Someone's the dumbest person in the room.
Old 10-29-2006, 01:06 AM
Morley Morley is offline
Stock 94 5.7? If so, you have an LT1 and that means optispark and that means $$$$.
You replaced the distributor? or just the cap?
Old 10-29-2006, 01:49 AM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
symptoms?
car cranks, im guessing..
can you hear a fuel pump?
can you check for spark on plugs?
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 10-29-2006, 05:56 AM
i replaced distributer , cap , & button
Old 10-29-2006, 05:57 AM
fuel pump is running & i do have spark to all plugs
Old 10-29-2006, 05:25 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: car won't start
it's a LT1 so the "distributor" is something call optic spark. it is a pain and can get expensive. make sure you have the car in time also.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 10-29-2006, 06:55 PM
does anyone know on the opti spark distributor where the rotor button points at tdc on #1 plug?
Old 10-29-2006, 07:07 PM
94 lt1 firebird 5.7 formula
DOES ANYONE KNOW ON THE OPTI SPARK DISTRIBUTOR WHERE THE ROTOR BUTTON POINTS AT TDC ON #1 PLUG.
I REALLY NEED HELP PLEASE.
Old 10-31-2006, 09:20 AM
Blue Bowtie's Avatar
Registered Offender
Re: car won't start
One thread per problem, please.
Old 11-01-2006, 12:35 PM
I HAVE A 94 LT1 FIREBIRD FORMULA : THANKS I WILL TRY THAT THANKS.
Old 11-01-2006, 05:08 PM
I'VE CHANGED BOTH.
Old 11-01-2006, 05:10 PM
Originally Posted by ikeyballz
symptoms?
THE FUEL PUMP IS RUNNING AND THE PLUGS HAVE POWER ALSO.
Old 11-01-2006, 05:13 PM
Re: car won't start
I DID POST ONE THREAD PRE PROBLEM I DON'T KNOW HOW THEY ALL CAME ALL TOGETHER.
SORRY ABOUT THAT.
