Old 10-28-2006, 08:02 AM
fred and mimi fred and mimi is offline
Angry 90 F-150 won't start.
Have a 90 f-150 4x4, V-8 it has been sitting for awhile. Only use it for snowplowing.. Fuel is getting to filter and there is spark. No fuel to schrader valve, though. Will start with starting fluid. Help....
Old 12-03-2006, 01:47 AM
cadauctions cadauctions is offline
Re: 90 F-150 won't start.
You just need a new fuel filter, and run fuel injection cleaner after you install it.
Thank you very much,
Dave
Old 12-03-2006, 01:47 PM
mechhound mechhound is offline
A new filter may be in order, but did you try turning the ignition switch on wait 5 seconds, turn switch off, back on again for 5 seconds. Do this atleast 20 times to get the gas up to the schrader valve. Do you have plenty of gas in the tank? Also do you hear the pump activate when you turn the switch on.
Old 12-10-2006, 08:39 PM
1990 1990 is offline
Sounds like the same problem I had with my 2wd 302 1990 F150.It probably runs good all day once it starts.Try unhooking the battery cable and reattaching it before starting. It may reset your ECM for start-up. The computer on mine finally gave up but drove me nuts until it died.
