Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 10-27-2006, 08:05 PM
s281er238 s281er238 is offline
Need Help On Supreme 95
My Low Collant Light Started Flashing Today But I Have Collant In There .my Water Pump Is Brand New I Changed It My Self 2 Months Ago My Thermostat Is Bran New I Changed It 5 Months Ago What Could It Be From Can It Be The Temp Sensor Has Gone Bad .need Advice If Anyone Has Had This Issue
Old 10-28-2006, 12:32 AM
Ian Szgatti's Avatar
Ian Szgatti Ian Szgatti is offline
Re: Need Help On Supreme 95
Have you actually taken the cap off the rad to look? (engine cool when doing this) You will have a coolant level sensor in your coolant overflow tank or the rad itself. If it is not submerged you'll have a light on. Try unplugging the wire to the sensor, your light should go off and you know the sensor is defective. If not, look for a short in the wiring.
Old 10-28-2006, 04:02 PM
Yes There Is Water In There And The Reserve Tank Is Full Too
Old 10-28-2006, 04:03 PM
Yes There Is Water In There And The Reserve Tank Is Full Too First When The Car Is Cool There Is No Flash As Soon As It Gets Up To Normal Heat It Starts To Flash And Then After A While It Stays On
Old 10-30-2006, 04:04 PM
Goose10202 Goose10202 is offline
Enthusiast
I had this symptom on my '95 Cutlass last year. The fix is simple. There is a sensor on the right hand side of the radiator (passenger side). It is mounted on the end cap up at the top just below the filler neck. That sensor needs to be replaced. It is held in with a clip. Simply remove the plug from the sensor, remove the clip and pull the body out of the radiotor and insert a new sensor and hook the plug back in.
Old 10-31-2006, 01:28 AM
What Do U Mean I Dont Have A Sensor Are U Talking About The Sensor That Is Under The Trottle Boday The Temp Sensor On The Driver Side Because I Dont Understand Where U Mean I Dont Have A Filter On The Passanger Side Of The Radiator My Air Filter Is On Driver Side Maybe Its Because My Car Is A 3.1 V6 Do U Have A 3.4 I Think It Is Thanks For U Help I Really App Ur Reply Let Me Know Iam Intrested In What It Is
Old 10-31-2006, 08:28 AM
Your coolant temp sensor would only indicate tempreture. Did you unplug the wire to the coolant level sensor yet? Try that.
Old 11-01-2006, 02:20 AM
Thanks A Lot I Founfd It And Changed It Today Hey Can I Ask U One More Thing Maybe U Had This Issue My Doors Everytime I Press The Door Lock On The Key Fob Or From The Door Lock Swich My Driver Door Somes Times Unlocks And Sometime It Doesnt . I Thought Maybe The Door Relay That Pulls And Pushes The Lock Was Bad So I Tested It With A Diff One But It Still Does The Same Is There A Relay Somewhere For This Locks Have U Ever Had This Issue
Old 11-01-2006, 10:40 AM
If it is only the drivers side door that chooses to work intermittenly, check the wiring going to the actuator. Chances are there is a loose/corroded/chafed wire. wiggle the powerfeed wires around while using your key fob to lock and unlock the doors.
If all your doors stop working at the same time, try replacing the battery in your key fob.
Old 11-10-2006, 03:45 PM
Suagrfoot Suagrfoot is offline
I don't have any answers for you although I'm having what may be similar problems with my 1994 Cutlass supreme. My automatic door lock buttons work fine from the inside of the vehicle, but my door key won't unlock the doors from the outside anymore. The key still works fine on the trunk. Also the ignition key is stuck in the ignition in the on position and won't come out. I had to poop the hood and strart pulling spark plug wires until it stalled, just to turn it off. I then un-hooked the ground cable from the battery so it wouldn't be on all night. The battery has a full charge, and if I hook it up I can start the vehicle and drive it, But I can't turn it off cause the key won't turn into the off position, to where I can remove it. Do you think the ingnition key problem and the door lock problem are related? Where should I start to look for the problem. Thanks for any ideas.
Old 11-10-2006, 05:20 PM
Im pretty sure you should have started your own thread.. if you do that, somebody will answer your question shortly!
Old 11-10-2006, 06:08 PM
Thank you for the quick response. I'll give it try. I thought I should probably have started my own new thread too, but I couldn't figure out how to do that. I'm still not sure how, but I'll keep looking for the spot to do it, for the next time. If I do get the old key out, where would I get a new one? Dealer?
Old 11-11-2006, 10:57 AM
yes, a dealer. Your key is obviously worn out. You could also get another steering column with a key from an auto recycler if you fail to wiggle your old key out. Do what costs right for you. But keep at that key.. wiggle it everywhich way you can while lightly turning it to the off position. It wont be easy, or take only a minute.. right now you have nothing to loose, so spend a half hour at it, and you'll probably get it.
