Old 10-27-2006, 08:57 PM
maxwinamp maxwinamp is offline
Tamiya 1/24 Ferrari F40
Time to get back to cars after a long break from car modelling
This is quite an old kit and there is a fitting problem for the back cover as below.. about 2mm difference for the chasis.
To rectify this, I saw off the bottom chasis and aligned with pin by drilling holes to the 'tubes'
To speed things up.. I use super glue gel with accelerator as 'putty' to secure the joining area.
(Will need to sand even later)
Fit problem rectified.
Old 10-27-2006, 09:04 PM
viperofoz's Avatar
viperofoz viperofoz is offline
Re: Tamiya 1/24 Ferrari F40
Thats funny, I built this kit years ago and dont remember such fit issues.
Are you sure the upper part of the engine cover is in the right position?.... not warped?.
Looking good though, keep it up
Regards, Dan
Old 10-27-2006, 09:31 PM
Samurai75007 Samurai75007 is offline
I love F-40's, nice start. what color are you thinking of going with?
Old 10-27-2006, 10:45 PM
Regards, Dan
Even after I remove the 'projection' on both side, there is still a gap... strange..
Originally Posted by Samurai75007
TI love F-40's, nice start. what color are you thinking of going with?
The normal Tamiya 'Italian Red'
I need to get the hang of polishing red.
Old 10-27-2006, 11:56 PM
Originally Posted by maxwinamp
The normal Tamiya 'Italian Red', I need to get the hang of polishing red.
Not bad, I would like to do an F-40 sometime though there are a few hard to find Ferrari's that I would like to make. Keep up the good work.
Old 10-28-2006, 10:42 AM
NissanSkylineGTR98's Avatar
Nice work so far, can't wait to see how it turns out. Always love to see a red F40.
Steve
Old 10-28-2006, 11:30 AM
ales's Avatar
ales ales is offline
Forza Schumacher
This is a weird problem you've got there, I don't have that on my kits.
I would be wary of the possibility you might run into further issues when you install the engine and subassemblies, as well as with the alignment of the rear suspension.
Old 10-30-2006, 08:42 PM
Jaymes's Avatar
Jaymes Jaymes is offline
nice start. check out MPWR's F40 thread...he cut off this tab that made the rear hatch fit perfectly iirc
Old 10-31-2006, 07:33 AM
Martsmodels's Avatar
Martsmodels Martsmodels is offline
Haven't tried this version although I have done the Italeri - the fit problems you mention are also brought to light in Alex Kustov's review at
http://www.italianhorses.net/Gallery...F40/TamF40.htm
Old 10-31-2006, 12:57 PM
Enzoenvy1's Avatar
I agree with being careful for the rest of the build. I dry fitted mine after I saw this and it has no issues where yours does?!?!?!
Old 12-06-2006, 10:35 AM
The engine
Added some wires to it based on reference pics..
I cut off the peg to realign the 2mm at the back
Bloody sink holes...
Old 12-06-2006, 11:07 AM
mhayward's Avatar
mhayward mhayward is offline
Nice detail work on the engine.
How does it all fit now after your modification to the rear chasis?
M
Old 12-06-2006, 11:10 AM
Gamerxz's Avatar
Gamerxz Gamerxz is offline
Hahaha.. SRG S.C can put your model on my diorama?
Old 12-08-2006, 12:09 PM
After spray can TS- 8 and gloss coated, wet sand to remove some orange peel.
Polish with Nuvus No.2
Ok.. now need to clean away the access rubbing compound with water and old toothbrush.
Old 12-09-2006, 12:07 PM
COMPLETED!!!!
MORE PICS!!!
