Old 10-27-2006, 05:08 PM
jeepgclwj's Avatar
jeepgclwj jeepgclwj is offline
Supercharger Question..
What are some of the things to expect or look for when a supercharger is going bad?
358rwhp/358rwtq with stock LS1 intake
A4 3.23 lid, pacesetter lts, ory, 243 heads, SLP LMI, ZO6 cam, BBK SSI intake, 85 mm
Old 10-27-2006, 06:07 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Supercharger Question..
You may hear a rattle from the coupler, this is a relatively inexpensive fix. Failure of the snout seal is another as you will see oil coming from the pulley area. You may start to hear some grinding. This usually indicates that the bearings are going. Failure of the supercharger to produce full boost is also an indicator of something going wrong. Of course if it seizes then that is a pretty good indication that it has gone bad. lol
Old 10-27-2006, 06:35 PM
jeepgclwj's Avatar
I do see oil coming from the pully area and I get a very faint smell of oil burning...
What do I expect next and does anyone think that this would fall under drivetrain warranty?
Wouldnt that also mean that I need to keep an eye on the supercharger oil level... Can someone point me into the right direction to check the oil I have no book on it yet...
Old 10-28-2006, 03:25 PM
Pontiac Guy
The warranty has expired unless this is a new supercharger. The snout seal is probably leaking. You can purchase the seal from several vendors. If it is only leaking a little bit, clean the area and keep an eye on the level. To check the level there is a plug on the front of the supercharger where the shaft comes back into the casing. You should see it easily since it is black and not the same color as the rest of the housing. The plug is removed using an allen wrench. To check the oil remove the plug and look at the level. You may want to stick your finger into the hole and if there is no oil on it the level is too low. Actually you should see the oil when you pull the plug. If it is low add oil.
Old 10-28-2006, 03:48 PM
jeepgclwj's Avatar
thank you,
Old 11-01-2006, 11:37 PM
bricker82's Avatar
bricker82 bricker82 is offline
Another question to piggyback off of this one...The dealership recommends a Supercharger oil change at 30K. I just reached that and found out that the S/C oil change is $125! Does this sound right?
Thanks,
Brick
04 GTP CompG 3.8L Supercharged
K&N FIPK/180Tstat/SSC Springs/GMPP STB's/Autolite APP605's/Aluminum Grilles/SPO Tips/17" AE Alloys 185's/2 RockfordFosgate He4410 Subs & 1 P4002 Amp
Old 11-02-2006, 12:25 AM
GTP420 GTP420 is offline
Send a message via AIM to GTP420 Send a message via MSN to GTP420
Fuuuuckkk thattt! You can DIY, it'll cost ya bout 20 bucks for the oil and somethin to siphon out the old oil with. Prolly a procedure around here somewhere....
Old 11-02-2006, 06:21 AM
Pontiac Guy
Purchase a turkey baster and a small piece of plastic hose that will fit over the end. Needs to be about 3-4 inches long and can be purchased at a home center. Remove the plug and suck the old oil out of the supercharger. Be careful, this stuff stinks. Remove as much as you can and refill with two bottles of GM supercharger oil. You can purchase it for around $10 per bottle from PFYC.com or ZZP.com. Replace the plug and happy motoring!!!
Old 11-02-2006, 08:21 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Thanks,
Brick
As usual the dealer is a Rip Off!!!
Do yourself a favor and do the SC oil change sooner. I do mine annually. Here is a tech procedure with pics. Stop at snout removal and coupler replacement.
Click here
The GM Supercharger Oil part number is : 12345982.
Timeslip 08/12/06
AF Community Guidelines
Old 11-02-2006, 08:31 AM
98gpking 98gpking is offline
Send a message via MSN to 98gpking
Thanks,
Brick
make sure though to only use the supercharger fluid from GM no fluid from ebay or from anywhere else. just the GM supercharger fluid in the blue bottle. its about 2 bottles at about 7 bucks a bottle
2000 grand prix GTP. CAI, 180 t-stat, u-bend and res delete, custom tuned PCM, shift kit
Old 11-02-2006, 09:38 AM
bricker82's Avatar
Thanks guys! I'll do that this weekend. $16 off of PFYC is a lot better than $125 to the dealer! What else should I do at 30K? Trans Fluid exchange?
Thanks Again,
Brick
Old 11-02-2006, 09:56 AM
Thanks Again,
Brick
i think at 30k a trans fluid would be a lil early. but better early then late. i know id need new tires by now so maybe a tire rotation, prob air filter they should be changed at ever 15k. other wise id say your prob still in good hands.
Old 11-02-2006, 10:48 AM
slimfatboy slimfatboy is offline
$16.95 at the local dealership is cheaper than paying for it with shipping too. Unless of course, if they cover that.
Old 11-02-2006, 10:49 AM
bricker82's Avatar
Thanks Again,
I have a K&N box filter that I clean. It's only been about 2000 miles since it's last cleaning. I think I'll have the trans fluid exchanged next week anyways.
Thanks,
Brick
Old 11-02-2006, 12:21 PM
unfortunately im stuck searching the online stores or driving 60 miles one way to get a few bottle of supercharger fluid bcause the dealerships out here wont sell the fluid out right. it sucks.
mine as well change the fluid if ya got the money. lemmi know when you sell your car man. its guys like you i like to buy cars from not like the last guy who didnt even know what soap and water was. literaly he didnt smell much better himself. ANYWAYS
