My 1997 Maxima AC does not blow cold air. The compressor cycles on & off every few seconds. I put a gauge on the low pressure side and it read 85-90 psi, way into the danger zone. It will not take freon. Occasionally while trying to put in freon there is a loud racheting sound from the area of the compressor. It only last a second or so. Any ideas?
Re: Maxima AC Problem
You need to watch both the low and high side at the same time you are adding freon. http://www.ackits.com/merchant2/merc...uct_Code=66773 http://www.ackits.com/merchant2/merc...e=DIY-STARTER1 http://www.ackits.com/merchant2/merc...ode=DIYADVANCE Before we could help we need to know the high andd low side reading at idel and at 2k rpm with the compresser running.
Thanks MT. I took it to an AC tech this morning. He ran all the checks and tells me it needs a compressor, dryer evaporator and a high pressure line.
Bottom line about $ 925. I am a pretty good amateur mechanic and have removed and installed engines and transmissions and rebuilt several engines over the years. Should I install the new parts then take it to a shop to evacuate and charge the system. Thanks. LEL |
MT
Thanks MT, I think that's the plan. LEL
If you flush and clean system I would see no need for the inline filter. The are kinda of a pain to install. If no special need on that system for it I would not use it. But get a second opion from. http://www.autoacforum.com/
