Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Exterior and Wheels
Exterior and Wheels This is the place for all exterior wheel modifcations.
Old 10-27-2006, 03:25 PM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
92 Front End swap
I'm just wondering, but what would it entail to swap the non-popup lights and hood onto the front end of a '91?
I know I would need the 92 hood and lights, but what else?
Any special drilling, cutting, welding, or the like
Not sure that I wanna do it, just thinking a/b it at this point. And on a side note, AF is too f'in addicting...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 10-27-2006, 03:33 PM
mike8818 mike8818 is offline
Send a message via AIM to mike8818
Re: 92 Front End swap
Fenders Bumper And Probably Wireing. I Also Think You Have To Cut Away Parts Form The Old Setup.
1979 pontiac firebird- for sale/trade
1978 Chevy Elcamino- parting out
Old 10-27-2006, 03:40 PM
Mikelb's Avatar
damn... maybe if my car goes down during the summer (hah, maybe... damn, that was a good one)... then I'll take the time to do it... Idk... my car needs a front bumper... why not some plastic surgery while I'm at it...
Old 10-29-2006, 11:49 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
This is what I pulled from the VFAQ
Has anybody ever converted their popup headlights to non-popup headlights?
This can be done too, but it is a significant amount of trouble. It appears that most people purchased the front end they wanted with their car, as information on this modification is limited.
According to Paul Bratina:
"The following parts must be replaced: hood, fenders, headlights, side marker lights. The front bumper can be kept (as in my case) but must be slightly modified. Replacing the bumper with a 92-94 makes the conversion easier. Replacing the hood is strictly bolt-on. The fenders are bolt-on except for where they attach at the very front (easily accommodated). Mounting the headlights (and to a lesser extent, the side marker lights) is by far the hardest part of the conversion, and is definitely not a bolt-on procedure. I certainly wouldn't consider it technically difficult. Mostly just time consuming.
I think it's worth mentioning a little bit about the costs involved in the conversion. First, assuming you get all the parts necessary at the wreckers, the parts alone would run somewhere in the $500-$1000 area. (Of course, some of this cost could be recovered with the sale of your old parts.) Then you have the issue of repainting the car. Unless one is interested in a multi-coloured car (all the various body parts that were necessarily replaced), I consider repainting the car to be absolutely mandatory. So whatever the paint job costs, could theoretically be added to the cost of the conversion. In my case, I was going to be repainting the car anyway, so that cost didn't "count". I really feel the thought process on this conversion should be something like: "I'm going to get the car repainted and while I'm at it, I'll throw in a conversion." Not the other way around--you know, do a conversion and throw in a paint job."
A quick & dirty method for keeping the headlights down is to remove the fuse that controls the headlight motors, or to rewire them under manual control. This keeps the lights down when they are on, and thus is sort of a 'non-popup' mod.
The Last Word:: George Johnson adds:
"I looked for what I believed to be a good amount of time for the popup to non-popup conversion wiring schematic. I apparently failed to find it, so I figured you might like to add it into the answer to the swap.
Popup Non-popup
Solid Red Solid Red
Red w/Blue Stripe Red w/Blue Stripe
Red w/White Stripe Black
Turn signal/running light assemblies will interchange."
95 Talon TSI AWD
97 Eclipse GST
