Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-27-2006, 02:24 PM
pennfire51 pennfire51 is offline
can somebody tell me why my horn keeps going off on my 99 isuzu rodeo
can somebody tell me why my horn keeps going off on my 99 isuzu rodeo. I took it to my mechanic and he told me the driver sideairbad went bad and that is why my horn kept going off in the middle of the night for no reason. So i replaced the driver side air bag, but now it still goes off in the middle of the night again sometimes it stops if i honk the horn. Any help would be very appricated.
thanks you
calvin
Old 10-27-2006, 02:43 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: can somebody tell me why my horn keeps going off on my 99 isuzu rodeo
http://isuzufaq.ibctech.ca/#faq26
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 10-30-2006, 05:35 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
check the switch under the hood on the pass side near the firewall it is covered by a rubber boot sometimes needs tweaking pull up on the bracket it is mounted to so that it will lift and make proper contact with the hood closed
Old 10-31-2006, 10:20 AM
that would cause just the horn to go off at weird times and it is constant. i know it is not the alarm going off. the last time i took it to my mechanic he told me the air bag was defective and that what was causing it to happen and it stopped for a couple of months and than it started going off again
Old 10-31-2006, 10:46 AM
Isuzu Guy
Contaction and expansion.
as it gets colder at night the pin can then loose contact to the pannel and then alarm goes off.
-Ryan
Isuzu Moderator
Car Show Tips
Old 10-31-2006, 11:05 AM
i do not think it is the alarm cause it is just the horn going off constant and than when i push on the horn it goes off. cause when the alarm going off the horn goes off and on
Old 10-31-2006, 06:57 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Try unplugging the alarm horn and see if that stops it, then you will know. The alarm system uses a different horn then the one for 'driving'. Its located on the passenger inner fender (in the engine compartment) behind the ABS module.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 11-01-2006, 08:53 AM
when i pull the fuse for the horn it stops going off and the alarm fuse is still pluged in
calvin
Old 11-01-2006, 11:03 AM
rodeo02 rodeo02 is offline
Lets try it this way: What ever you do, dont touch the hood pin switch!!
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 11-04-2006, 10:31 AM
smarquez1 smarquez1 is offline
I have the same problem on my '98. Ryan, it's definitely not the alarm. This is a constant tone from the Horn that only pulling the horn fuse will stop, So i drive without a horn. I have tried checking all the wiring from the switch to the horn, suspecting a short that was grounding out and causing it, but no luck. I even pulled the steering wheel and cleaned all contact points to try and find a problem there (dangerous with the airbag, I know). But it will randomly go off in the middle of the night with a constant tone form the horn (not the alarm) and pressing the horn on the wheel doesn't stop it anymore. Only pulling the fuse from inside the dash in your underwear while freezing your nuts off will do it. The nice thing is, with the dome light on and the horn blaring like crazy, all the neighbors get to see you shiver . . .
Anyone have a fix for this--I'm stumped and it's making me crazy!
sm
Sinner
98 Isuzu Rodeo 2 wheel drive/manual
86 Suzuki Samurai
78 K5 Blazer, 6" lift
66 Chevelle
Old 11-05-2006, 10:29 AM
rodeovyn's Avatar
rodeovyn rodeovyn is offline
Cool Re: can somebody tell me why my horn keeps going off on my 99 isuzu rodeo
I'm going through this exact same problem with my 99' Rodeo right now. I took it to the Isuzu dealership and they said I will need some new part that is under the steering wheel and airbag? I was gettinga new air conditioning system and wasn't willing to drop anymore money at the time, the AC system cost and arm & leg. I've resulted to pulling the fuse under the hood.
I hope someone can offer a do it yourself fixit WITH PICTURES. I really would like to know how to remove the cover off the steering wheel.
thanks you
calvin
Old 11-06-2006, 08:44 AM
i know if someone can help us fix this problem it would be very appricated cause it is a little embarassing running out in the middle of the night in my boxers to pull the horn fuse.I hope someone knows a way we can fix this problem and have some peaceful sleep
calvin
Old 11-07-2006, 09:28 AM
Rodeovyn, if you can ID the part positively from the dealer (a part number would be great) then we can order it from St. Charles Isuzu. I have had the steering wheel apart trying to fix this, so know that it can be removed. Be afraid of the airbag, but with the exercise of extreme caution and disabling it as much as possible prior to opening the wheel, this could be the fix we are looking for! Let me know, even PM me with that part. Once I get it and get the wheel off and the part replaced, I can post a write up (with pics, I hope) and get this fixed. Did the dealer mention if it was a common problem at all?
sm
Sinner
86 Suzuki Samurai
66 Chevelle
Old 02-16-2007, 08:51 PM
prikolist prikolist is offline
I am joining the club. My horn goes off randomly at night. Please let me know if you figured out how to fix the problem.
isuzu rodeo 99, 4wd 3.2L
Old 02-17-2007, 08:39 PM
I never did--and then the car was totalled just before Thanksgiving. The only solution was to pull the horn fuse and simply not have a beep when I set the alarm or a horn at all.
Sinner
86 Suzuki Samurai
66 Chevelle
