Old 10-27-2006, 02:10 PM
sjr8ut sjr8ut is offline
crazy '99 G. Caravan problem
Hey everybody,
I've got a 3.8L '99 Grand Caravan, 260K miles. When the steering wheel is not exactly straight, the car will not start. No clicks, cranks, nothing. I have to turn the wheel to just the right position and it will start right up.
Anyone have any ideas?
Is this something I could fix myself?'
Thanks for your help.
Old 10-29-2006, 09:28 PM
Re: crazy '99 G. Caravan problem
Hey guys--no replies so I'm taking it that nobody else has had this problem. Does anyone have a clue what could be causing it? I don't know where to start.
Thanks.
Old 10-30-2006, 12:08 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
My guess is something you have probably already guessed. You will have to pull the steering column apart and look for an intermittent open in the power wire off the ignition switch. On a 98 GC it's a yellow wire off the ignition switch to the 10 amp fuse #10 on the junction block. Check continuity with a meter. Should come and go as you turn the wheel. The wire is broken probably within the wires insulation and making intermittent contact. Look for bumps or dark spots on the wire.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 10-31-2006, 01:10 PM
Thanks for your reply. I'll have to get that column apart and take a look. It will be nice to get this problem taken care of...
Old 10-31-2006, 09:10 PM
vipergg vipergg is offline
If you are going to pull apart the column just make sure to pull the battery so you don't set off an airbag .
