Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 10-27-2006, 01:33 PM
BJP01 BJP01 is offline
Heater problem in '94 Accord?????
I can't figure this one out....I have a '94 Accord, when I turn on the AC and move the "thermostat/dial" to the coldest setting, it works fine, if I move the setting towards "warmer", the air coming out of the unit does not ever get warmer; and, if I switch it over to "heat", the air continues to blow cold?! Please help if you have a clue what I should check/do. Thanks, Brandon
Old 10-28-2006, 01:13 PM
somick's Avatar
somick somick is offline
Re: Heater problem in '94 Accord?????
Sounds like you have air pockets in the cooling system.
Park your car on a hill nose up with the radiator cap off. Run your engine. You should see air bubles comming out.
Did it just start doing that?
Did somebody bypassed your heater?
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 10-28-2006, 05:05 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Sounds more like your blend door is jammer or not working.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 10-28-2006, 10:20 PM
Thank you both. First yes, it just started. Second, no one has done anything to it. Finally, yes, I think it was stuck "closed", so I found it and eased it open manually so that I could get the heat to work...good news is, it'll probably be a few months before I need to worry about changing it back to AC. Again, I truly thank you both for your thoughts.
