abs light will not go out
howdy folks, anyone had a problem with abs light not going off? i replaced master cylinder, check valve, pads. brakes work fine , cant tell if abs works or not. junction plug in front drivers side of engine shows no damage. thanks all
Re: abs light will not go out
To get the light of you need to fix the problem. You need to get it on a ABS capable scanner and get codes/find out what the problem is. There is a lot of speed sensor problems on ABS brakes . But get the code and post back cod e and someone will help. Along with year make and model of car. MT
I bugged out the wheel sensors and had to replace the RF hub bearing assembly a common fix to ABS when a wheel sensor dies..
Good Luck
Bass 00' Park Ultra ![]() 94' Park Ultra 94' LeSabre 96' LeSabre
thanks guys, will try to get that done
