Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-27-2006, 11:25 AM
boyertownMidnight's Avatar
boyertownMidnight boyertownMidnight is offline
Send a message via ICQ to boyertownMidnight Send a message via AIM to boyertownMidnight Send a message via Yahoo to boyertownMidnight
when should i shift?
Me and my dad just built a 2.0 n/t stroker. heres a mods list,
injen intake,k&n filter, eagle 4g64 6-bolt crank, custom 10-1 pistons,300cc injectors W/ fuel controller, all bearings are crower or sealed power, turbo intake cam, ported head and intake manifold, ported 1g n/t throttle body with egr block off on intake manifold,pace setter full exhaust 2.5, and theres some more mods.
im not sure what its gonna dyno at or what the quarter mile times will be, but i did keep up the whole race with my dad driving my other stock gst with a
14b. My question is when should i shift some people say i needa shift sooner then a stock, when i shift at 4500-5000 it seems like im really shifting at 7000rpms what gives?
Old 10-27-2006, 11:39 AM
eclipsed at 3am eclipsed at 3am is offline
Send a message via MSN to eclipsed at 3am
Re: when should i shift?
did you mess with the trans at all? now im no expert but i think that if you beefed up all those internals then you should be fine shifting at 7k. maybe even 7500 - 8k. dont drive like that all the time though, normal driving just shift at like 3k or 4k.
if the different ratio pistons change anything then i have no clue.
oh and congrats on the rebuild.
eclipsed @ 3am
http://www.cardomain.com/ride/2505283
Old 10-27-2006, 02:54 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
elaborate on this a little
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 10-27-2006, 04:10 PM
sorry its a 2.0 block but now its a 2.4L. Umm i shifted alot of different n/t dsm's for years and i know the sound that engine makes and different RPM's,, and it sounds like im tacking at 7000RPMs when im at 4500rpms
Old 10-27-2006, 04:17 PM
maybe it wants you to get a turbo dsm.
id imagine the engine would be a little bit louder, you have big things going on in there. plus, its .4 more liters of exhaust coming out. ill bet that it will quiet down a little after a couple hundred miles. does that engine break-in thread have anything to do with engine rebuilds too? if so, or somewhat, change the oil a couple times too.
eclipsed @ 3am
Old 10-27-2006, 04:22 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
4g64 crank in a 2.0 block = 2.3. I would rev it to 7 and not much farther. A stock car not setup for power up there isnt going to make much up there.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 10-27-2006, 04:27 PM
what he said
eclipsed @ 3am
Old 11-01-2006, 03:59 AM
kjewer1 kjewer1 is offline
AF - Advisor
The only way to find out is to try several different shift points at the track. Way back in the day I found that going to 7k in first on the stock t25 but then only 6500 or 6k in the other gears was worth a worth tenths in the ET and a few mph.
Also, even the 2.4 is not a 2.4. It's a 2.35 which rounds up. A 2 liter with a 100mm stroke bored 060 is the exact same thing with "short" pistons and a 6mm lower deck, for anyone that was wondering. 2.3, 2.4, who gives a fuck.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
