Old 10-27-2006, 11:12 AM
ryan99 ryan99 is offline
coilover spring installation
need help, i've got a 97' cavy.i just installed a adjustable coilover springs with stock shocks.but it hasn't drop my cavy.there's something blocking the adjuster in the front.can't get it low enough.i think it's the spring perch.how will i remove this?thanks...just starting to tune my cavy
Old 10-27-2006, 12:07 PM
Lances133's Avatar
Lances133 Lances133 is offline
Send a message via AIM to Lances133
Re: coilover spring installation
Did you get them from eBay?
Old 10-29-2006, 09:52 AM
yeah,i got them from ebay.i know there are lots of shit there.but i only got to know when i registered here.
Old 10-29-2006, 12:23 PM
Lances133's Avatar
I wouldn't bother with them man, they're gonna make your ride so stiff, the problem with them is that they're not made for the specific car's specs, meaning they're just generic springs, not springs for how a Cavalier's suspension should be.
Old 10-29-2006, 09:09 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
... and your suppose to trim the perches. Not going to come off as a prick, but a little research would have pointed that out to you along with stayin away from those springs. Also putting those on your stock struts was the worst idea ever. They are prolly already blown or will be in time.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 10-29-2006, 10:50 PM
PsychoJJ's Avatar
PsychoJJ PsychoJJ is offline
Send a message via AIM to PsychoJJ
Since when has comming off like a prick stopped us from passing on info that people need to not screw themselves in the long run? Also I agree the sooner you ditch the evil and go with god the better. As for already blown I give it at least two weeks. Need to have more faith in stock components cody.
Even pure genius is born out of insanity!
Big thanks to Lance for the sig pic.
Old 10-30-2006, 05:03 AM
sorry guys, i'm not that blessed like you guys here which can get parts that easily.i'm not from US.the only option i had was to buy from ebay.
how would you know if you had a blown shocks?i've been running low for a year now with a stock shock and welded springs.(again,availability of parts is not that easy)and my mechanic says it's still ok.i've been trying to browse for websites which can deliver international,but can't find one.so,again.sorry to pissed you guys.i'll post pics of my car soon so you can get a look of it and see what else i can do with it.thanks...
Old 10-30-2006, 06:00 AM
hey guys,which kyb shocks should i buy?is it ok to use them with the coilovers from ebay???
Old 10-30-2006, 08:44 AM
Lifted GMT-360!
No, KYB product will work with those. The only ones that would possibly hold up are the AGX line. But KYB only warrentys those up to a 1.5" drop, and if you put coil overs on them, they will know. YOur best options are Koni, Tein's, Tokico D-spec, thats pretty much all that will work with coil overs.
Old 10-30-2006, 11:58 AM
Lances133's Avatar
They have name brand stuff on eBay too you just gotta type it in, type in like "Cavalier kyb" "cavalier tein" "cavalier koni" - are you sure you wanna go with coilovers? A good set up and much more expenisve then lowering springs and you pretty much get the same lowered effect with a better ride.
Old 10-30-2006, 04:59 PM
BabyCavyZ BabyCavyZ is offline
what setup do u think would give the best ride in your opinions srj and lances? cause im plannin on doin it sooner or later
1999 Cavalier Z24 - Visonik 700W Amp, 2 12" Rockford Fosgate P1's, Pioneer Headunit, Magnaflow Dual Exit Exhaust, Magnaflow Cat Converter, Pacesetter Header, AEM Short Ram Intake.
Future Plans: Camshaft, Pulley kit, Clutch kit, B&M short shifter, head and taillights, 15% tint
Old 10-30-2006, 06:04 PM
Lifted GMT-360!
I have ridden in 2 different j-body setups. None of which have been coil overs.
Goldline springs on Koni reds. - Extremly hard and a kidney buster, held the road very well.
Eibach Prokit and Kyb AGX - My own. Stiff but not as stiff as the goldlines, also holds the road extremly well.
Coilover good combos are ....
Tein SS straight up..
Ground Control and Koni
Rksport Prostreet
Old 10-30-2006, 06:13 PM
how much did u spend on ur setup? or if u got a hook of sum sort wat would be a good price that i should look for?
Old 10-30-2006, 07:07 PM
Lances133's Avatar
I bought my springs and struts off ebay for around $500 for both, springs and struts are much cheaper then any GOOD coilover set, for a good coilover set you're looking at 800+
Old 10-30-2006, 09:41 PM
Lifted GMT-360!
Eibach Prokit - $235
Kyb AGX struts - $520
= $735 including taxes.
I got my AGX's when they first came out, they have now since dropped in price. The prokit will be around the same price however, maybe a tad bit more.
Here is what my setup did for my car...
Before..
After..
