Go Back   Automotive Forums Car Chat > Fabrication & Tools > Metal Shaping and Welding
Metal Shaping and Welding Discuss metal shaping and welding techniques. Share your projects or tips and tricks.
Old 10-27-2006, 10:56 AM
Tercero Tercero is offline
Welding the frame of my Saturn SL1
I have a 1997 Saturn SL1 with approximately 136,000 km on it. I took it into a quick oil change service place today, and the service manager asked me to come over and have a look. The frame rails on the driver side are starting to rot out. It's actually come away in some places, allowing the motor to sag by 1 or 2 inches on that side. I was floored. The rest of the car is in excellent shape, and I've kept really good care of it.
I brought it home, put it up on ramps and slid the dolly underneath, and it really is rotting. I could put a screw driver through in some places on the unibody.
So, my questions are,
Can I cut out the rot on the frame, and weld in a new piece, or should I leave the stuff in place, clean off some nice areas on the frame to get a good weld, and weld pieces to the frame.. I have a good Lincoln SP-175 (240v). I'm just a hobby welder, and have only used the welder without gas. Should I weld with Co2 or Argon mix or just shielded wire, and what wire should I use. Can I damage any of the elecronics in the motor if I weld with mig? What precautions should I take? Any help, hints, ideas or advice is appreciated. I'd take it to someone in town, but, apparently no one locally repairs frames. Only sheet metal. I don't want to junk my car.
Old 10-28-2006, 01:16 PM
Re: Welding the frame of my Saturn SL1
Never mind. I got the answers I needed. It's the engine cradle, not the frame that went. I just need to find a replacement and swap it out.
Later,
T.
