Old 10-26-2006, 09:11 PM
joshua43130 joshua43130 is offline
instrument panel not working
I had to change the battery in 02 cavalier. After changing the battery NOTHING on the instrument panel works(gas gage-mph-odometer etc...) Called dealer, they said to hold the battery cables together for 30 seconds to restart computer. Didn't work. Any suggestions.
Old 10-27-2006, 12:43 AM
Evilmonkey1177's Avatar
Evilmonkey1177 Evilmonkey1177 is offline
Send a message via AIM to Evilmonkey1177
Re: instrument panel not working
Did you check the fuses?
Old 10-27-2006, 06:57 AM
homerr homerr is offline
I had the same problem after taking out the battery to replace the upper rad hose (go figure). All I did was disconnect the ground wire on the battery and hooked it back up and all was back to normal.
Homerr
Old 10-27-2006, 07:25 AM
I did check the fuses. I will check the ground wire and let you know. Thanks
Old 10-30-2006, 07:43 PM
I finally tried to unhook the ground wire. Well, some of the lights come on but they stay on with the key off(service engine, water, etc.) Still no gas gage, mph, odometer etc. Any other suggestions?
Old 10-30-2006, 07:57 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
try leaving the battery completely disconneted overnight, it might not work, but its worth a try
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 11-04-2006, 07:18 PM
T_rev87's Avatar
T_rev87 T_rev87 is offline
check ur fuse
Old 11-04-2006, 07:19 PM
T_rev87's Avatar
check ur fuses
