Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 10-26-2006, 09:53 PM
kntrobison kntrobison is offline
oil consumption
I work in a shop we rebuilt a motor in a 96 impala ss it has a LT1 motor. We are now having an oil comsumption problem oil is seepin on to the valves and puddling everything is new the heads have been checked twice and have even replaced the intake any advise or comments will be appreciated
Old 10-27-2006, 06:22 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: oil consumption
Correct valve seal installed? and installed properly?
Worn valve guides?
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 10-27-2006, 08:02 AM
Re: oil consumption
according to the machine shop everything is correct the heads have been gone thru twice the oil seems to be coming from between the intake and the heads seeping thru the gaskets
Old 11-07-2006, 05:05 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: oil consumption
Sounds like the machine shop took too much material off the head deck surface and now the intake mating surface is off. You may need a head gasket shim (if it's available for that engine) to bring the heads back into alignment, or you may need new heads to correct the issue.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 11-07-2006, 07:38 PM
maxwedge maxwedge is offline
A990 racer
Re: oil consumption
If you remove the intake and remove the intake gaskets, lay the manifold back on and see how much space is between the heads and the intake, if excessive the end rail ends of the block should be milled to comp for this and/or the intake side of heads, but a lot would have to taken off the head for this to be an issue, usually .020 or more.
