Old 10-26-2006, 06:03 PM
scooter38 scooter38 is offline
too much play in steering wheel...
i have a 88 s-10 blazer 4WD and there is a lot of play in the steering wheel,
i mean a lot!!! is there a way to maybe adjust the steering to get some of the play out? its really annoying moving the steering wheel back and forth 4 or 5 inches constantly to keep it between the yellow lines..
Old 10-26-2006, 06:46 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: too much play in steering wheel...
i had this problem. you can tighten the adjustment screw/nut on the steering box. loosen the screw with an allen wrench, then tighten the nut itself with a wrench while holding the allen wrench. after you are satisfied, tighten the allen screw.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 10-27-2006, 12:00 AM
Marcinko Marcinko is offline
Could we get a picture? My sterring is pretty good (all new components), but would still like to know exactly where to look. If possible...thanks!!
Old 10-27-2006, 06:23 PM
Thnxx for the reply, i will try this first chance i get!!!
Old 10-27-2006, 08:25 PM
Blue Bowtie's Avatar
Registered Offender
Actually, the adjustment is the other way around. The locknut is backed off to allow the hex recess set screw to be adjusted, then the locknut is tightened to hold the adjustment. Be very careful about how much adjustment you make, since excessive preload of the sector shaft can lead to rapid gear wear. The proper method is to disconnect the steering shaft and measure torque required (in inch/ounces) to turn the input, but almost no one does it that way.
Old 10-27-2006, 09:10 PM
ZL1power69's Avatar
GM S-Series Mod
here ya go. i got the steps backward (my bad) but they are in the pic.
Low 11 sec sleeper
My Cardomain
Old 10-27-2006, 10:20 PM
laxman21's Avatar
laxman21 laxman21 is offline
Damn. Sound like I will have to give it a try.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
Old 10-29-2006, 01:25 PM
Thanx a lot!! it worked!! i turned it about 1/4 to 1/2 a turn clockwise and it made a lot of difference, very little if any play in steering wheel now.
Old 10-29-2006, 04:01 PM
Registered Offender
You might also want to check Item #1 in the diagram ZL1power69 provided. Loose idler arms are common, and can contribute to a lot of steering slop.
