Old 08-28-2001, 07:26 PM
dcb85 dcb85 is offline
Send a message via AIM to dcb85
Question ?? Grinding noise, car shakes ??
I had just gotten a 1990 dodge shadow, which hadnt been driven in about 6 months. A few hours after i got it home, i jumped it to let it run for a while. But when i did that, the car started making a grinding noise, like metal grinding against metal maybe? And the car was shaking more than a normal car shakes too. Any ideas as to what the problem may be? And if possible, if itll be extremely expensive to fix.
Thanks for all feedback.
Darin
Old 08-29-2001, 01:45 AM
TheMan5952 TheMan5952 is offline
Volvo Guy
Send a message via AIM to TheMan5952
Is it a Automatic or a Manual transmission?
-Joe- '02 Volvo S60 T5
Sold!1993 volvo 850
Intake, Exhaust, Springs, Shock, I.C.E.
Old 08-29-2001, 11:28 AM
automatic
its an automatic transmission
Old 09-10-2001, 04:25 AM
Trigger351's Avatar
Trigger351 Trigger351 is offline
Cool
Sounds like it could be the starter motor staying meshed with the flexplate gear. I have had it happen on cars that havn't run for a while. If this happens its criticle not to rev the motor as it will wreck the starter motor.
Have you tried it lately?
MUSTANG powered by FORD
http://www.tmaauto.com/
Old 09-10-2001, 07:11 PM
thanks ill have to look into that, but im thinking now that it might be the air conditioner belt bearings lacking grease because it was out in the sun and it dried up. when the air is turned on, it vibrates more noticably. its mounted on a 4 cylinder so its not as sturdy as it would be if it was a 6, which would account for the shaking, which i guess is unavoidable
but thanks for the feedback ill check into that too to be sure
thanks
darin
Old 09-10-2001, 11:38 PM
Volvo Guy
Also check the Auto tranny fluid level, remember that the car has to be running at warm Idle in neutral (set parking brake) to get a accurate reading.
Sold!1993 volvo 850
2000 Ford Mustang Grinding Noise While Idling Starbucksinhand Mustang Problem Diagnosis 1 02-03-2010 01:59 PM
2001 Accord Manual --weird hissing / grinding noise from Back seat area! shivparekh Accord/TSX/Accord Hybrid 7 01-10-2010 07:42 AM
98 Stratus Grinding Noise pcjunkie7 Stratus 4 06-22-2009 07:21 AM
1999 Ford Expedition (E.B. Edit.) -Loud Grinding / Crunching noise in first gear UnluckyDucky Expedition 0 03-13-2009 06:03 PM
Car makes a loud grinding noise and won't pick up when it rains. caguas64 Eighty Eight 1 12-30-2004 09:05 PM
