Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 10-26-2006, 05:24 PM
import shark import shark is offline
Question 95 lebaron gtc bogging
My friend has a 95 lebaron 3.0 convertible automatic. It has an intermittant bogging issue. It runs fine up to 3000 rpms then the tach drops and it starts sputtering. It seems like it isnt getting fuel. You have to press the accelerator slowly and lightly as pressing it hard makes the problem worse. Any help or suggestions would be appreciated.
Old 11-04-2006, 04:56 PM
ricebike ricebike is offline
Re: 95 lebaron gtc bogging
do you know how to do the key trick to retrieving trouble codes?
turn da key "on-off-on-off-on" w/in a few seconds w/out turning the engine on...
then, you'll see a couple of flashes from the check engine light on your cluster. long flashes & short flashes...
code 55 means all's OK from the car's computer.
or mebbe, when's the last time you have changed the gas filter?
Old 11-06-2006, 03:28 PM
Joric theredbaron's Avatar
Joric theredbaron Joric theredbaron is offline
Arrow Re: 95 lebaron gtc bogging
I posted this responce to PFC Gardner's post 10/23 askin a similar ?? on his 2.5 that bogs..
Sounds like a fuel problem, possibly blocked in the filter area, or worse a partially blocked catalyst, try taking the cat off an see what happens, apart from the noise the revs shud fly up. So its a cheapy fix if its filters.. or a few $$$ more for a catalytic converter..
Theres also a post from Kmaniac on the same site thats longer and gives some other things to look for.. check it out.. might be helpful
Also, you can get fault codes at
http://minimopar.knizefamily.net/fault/
Joric
Friends dont let friends drive imports
