| Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here. |
4.6 dohc interference?
some quick qs;
is the 4.6 dohc from the markViii or cobras a interferience motor? does any of the ecus have eprom chips? or 24 bit chips that i can flash from home for cheap? does anyone know a good/cheap place to get forged interals for the motor? what is forged already in the motor? do these respond well to turbos? or twins? and lastly what manual trannies go behind this? can the old 5 speed from the 5.0 hook to this motor (86-93) |
Re: 4.6 dohc interference?
Well the Cobras already have a better trans than the old fox body mustangs. The motor uses timing chains not belts and is really not considered to be an interference motor. After that, I don't really know what cobra you are talking about. The 96-98 Cobras are different from 99-01 Cobras and the 03-04 Cobras are also different. They all have 4.6 DOHC motors but they are all different. Only the 03 and 04 have forge internals, and they respond very well to turbos, being that they are actually already supercharged.
what i ment was who makes forged interl for them for cheap?
how much boost do the stock internals take then (the ones without stock forged pistons) * 1993-1998 Lincoln Mark VIII, 280 hp (209 kW) and 285 ft·lbf (386 N·m) * 1995-1998 Lincoln Continental, 260 hp (194 kW) * 1997-1998 Lincoln Mark VIII LSC, 290 hp (216 kW) * 1999-2002 Lincoln Continental, 275 hp (205 kW) * 2003-2004 Mercury Marauder, 302 hp (225 kW) and 318 ft·lbf (431 N·m) * 1996-1998 Ford Mustang, Cobra, 305 hp (227 kW) and 300 ft·lbf (407 N·m) * 1999/2001 Ford Mustang, Cobra, 320 hp (239 kW) and 317 ft·lbf (430 N·m) * 2003 Ford Mustang, Mach 1, 305 hp (227 kW) and 320 ft·lbf (434 N·m) * 2004 Ford Mustang, Mach 1, 310 hp (231 kW) and 335 ft·lbf (454 N·m) * 2003-2004 Ford Mustang, Cobra, Supercharged, 390 hp (291 kW) and 390 ft·lbf (528 N·m) * 2003-2005 Lincoln Aviator, 302 hp (225 kW) and 318 ft·lbf (431 N·m) I am looking at geting the mark Viii motor though. with the 280 not the lsc unfortunatly |
Everyone makes forged internals for them. Ford makes them even. Pick up a Muscle Mustangs and Fast Fords at the supermarket and you will see plenty of adds. Or just do a quick google search.
any sugestions though preferences for some low comrpession say 9:1?
I would most likely model the motor after the 03 cobras because its known to work. The 03/04 cobras had 8.5:1 compression.
96-01 cobras come with a forged crank. stock engine will take 8-12psi safely (12 intercooled) 10 w/o. but then again it's not a definite, if you don't have it tuned properly it won't take 5psi without blowing up.
07 jeep cherokee srt8 99 saleen s281 05 cbr 1000rr |
The Mark VIII are not built for higher HP, the cranks are weaker and other internals, Get a Mustang SVT engine. A bullit is the same engine as the mark VIII.
