Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 10-26-2006, 11:22 AM
rcandersonmn rcandersonmn is offline
Sl1 electronics problem
I've been having a electronic system problem with my 1996 SL1.
It is like the entire electrical system turns off. What I mainly notice is that the clock resets and all the radio preset are lost when I start the car.
More troubling is that a couple times in the past week, the shutdown occurs while the car is running -- at which point everything shutdown including the engine. Everything comes back on immediately and I am able to restart the engine with no problems.
Any ideas??
Old 10-27-2006, 04:04 PM
samprix samprix is offline
Re: Sl1 electronics problem
Check battery cables and remove corrosion.
check aternator connections for possible short
check main system grounding cables, don't forget about the one under the air box intake, sometimes battery corrosion works its way down there, out of site because the air box obstructs visibility.
Old 10-29-2006, 06:48 PM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
anything been replaced recently?
Ian
Saturn Tuners Club-OH Chapter President
1993 Saturn SC2 rebuild project for dad
1995 Saturn SL2 current daily driver /w a lot of work
2007 Chevy Cobalt injen cai, full lsj exhaust, dc sports fsb, progress springs and rear sway bar, enkei wheels/hankook rubber --*boost in progress
Old 10-30-2006, 12:32 PM
Had some work done a couple of months ago, mainly tune up stuff -- spark plug wires, etc. The problems I described was happening once in a while before I had this work done.
Old 10-30-2006, 05:44 PM
yeah, you want to check all your battery connections, to start, alternator, fuse box, ground. thats the first thing i would check into.
Ian
Old 11-16-2006, 11:53 PM
tech 28 tech 28 is offline
Check The Instument Panel Junction Block I Have Seen Alot Of Terminal Tightness Issues There.go In From Drivers Floor Area And Unscrew The Connector Bolt (7mm) Then Inspect For For Corrosion Or Signs Of Arcing.
