Hi guys, I have a 2002 Wrangler. Sometimes when I try to start the jeep it fails to start (No lights, bells or whistles). I get a jump start and it starts right up. I can go days with any problems and then all of the sudden, It acts like the battery is dead again, give a jump start and it starts back up again.
I've gotten the battery and alternator tested and they are both fine. I've cleaned and checked the battery terminals and they are both fine. I have no clue . Summary: Battery drains; no specific time line, days or hours after driving; all seems fine after jump start; battery and alternator tested fine. |
Re: HELP with battery
O yea, the battery dies out completely. The green eye turn black.
I would check a volt meter on each of your fuse lines in your fuse box.
You may have a hot line that is constantly draining your battery even when it is not on.
97 Jeep Wrangler SE 2.5L Things I've repaired: Thermostat: Crankshaft Position Sensor: Radiator: Water Pump: Fan Clutch: Wires: Dist Rotor: Dist Cap: Plugs: Disc Rotor: Pads: Sway/Stabalizer bar links: Axle Shaft U-Joints : Transmission swap : Brake line : Shocks : Rear Pinion Seal : Transmission Mount |
I would have thought it's the fuse but here is the strange part.
I can go days with out driving it (in theory draining the battery) but it starts right up. But then I drive to work, park it for 4 hours and then it wont start. If it was a constant drain, wouln't I have had problems when I don't drive it for a long time? |
This happened to me a couple of times (but it might not be your problem though). When I turned off my jeep I turned the key tooo far and the accessories came on. I did not notice that they were on because just the radio would have shown me that the igition was on. I got a dead battery and then everything worked fine.
So, now when I get out of my Jeep I re-check that the key is totally OFF. Hope this helps you Happy Jeepin
www.jeepforum.com; www.socalultimate4x4.com 1998 Wrangler (replaced my 88 XJ) 21' Mini Winnie (replaced my Pace Arrow) |
Are you posting the finished repair??
guys I found out that my fog lights switch (the thing that looks like a turn signal) is so sensitive that when i close my door it turns on and drains my battery. Just in case you same the same problem.
